Hello all;
As i am nearing 100k on the clock i am researching timing belt and components replacement.
My questions are as follows:
1) As well as the belt and the tensioners i will also replace the water pump, however should i replace any other component(s)?
2) Would you recommend making any modifications or fitment of any aftermarket parts such as cam gears while this work is carried out?
3) Who in melb (near south east if possible) can i trust to have these done without getting ripped off?
4) Approx. what are the costs involved?
I should add that the car is a sII R33 GTS-T, stock apart from cat back exhaust and air pod, but soon to have custom 3inch dump/front pipe and high flow cat.
Any information will be valuable.
Thanks!
https://www.sau.com.au/forums/topic/22979-mods-while-timing-belt-replacement/
Adj cam gears sound good....and will also have the radiator flushed.....
$80 is very reasonable....are there different brands with variying quality?? dont mind paying more if better...
and is anyone able to recommend a reputable workshop who is experienced with this work?
Thanks for the replies...
ok genuine nissan.....hopefully they will have them in stock...
i am in southeast, i was told that blackburn nissan do a lot of work on skylines...anyone had any experience with them??
I know and dealt with AVO for many years....but do not know the others mentioned.
I guess i will have to go out to each to meet and make up my mind.
Guest INASNT
Originally posted by coco69
what sorta gains can be expected form adj. cam gears?
denham, yu were talking about yur cam gear giving yu earlier boost response in yur other thread i think, thats a possibility with adj. cam gears?
my cam gear is surrently at -2.5 degrees!
the cam gear plus the lightened flywheel plus the ebc is bringing 1 bar of boost by 2000rpm
personally i wouldn't take my car to get work done at any nissan dealership.
when you go in and ask for a timing belt for an rb25, and they say, are you sure its an rb25, not an rb26, then say, is that twin cam or single your after......
gets you wondering, what wacky tabacky they were smoking....
i reckon you might as well wack on a front mount intercooler aswelllll
thanks for the nissan dealership info guys....
i think i am better off taking the beast to one of the performance joints as they probably have done this kinda work many times and are very experienced with skylines....just have to decide which one....
i think changing the cam gears will be of more importance in the future when i get more mods done, but as the engine is relatively stock i wont gain much in terms of performance??? please correct me if i am wrong...
dabigwolf
I have been thinking about the intercooler for a while but my concern is that the standard ECU will not be able to cope with it.
Is this so? do u think the engine will retain its smoothness and drivability?
Ideally i want an aftermarket ECU like the autronic but for the time being its not high priority.
I hope someone with standard ECU and aftermarket intercooler will shine some light on this for me....
Thanks.
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
