Hey guys,
I'm starting to look at turbo upgrades (I've got a funny feeling that my turbo is going to let go soon)...I'm looking at a billion and one different options...
I have read the FAQ in the DIY section...and has given me good ideas
I was looking at KKR Turbochargers (the KKR430 or KKR480) has anyone use this on their Stagea and how does it go?
https://www.sau.com.au/forums/topic/229806-kkr-turbochargers/
  • Replies 45
I did read alot of turbo forums and got conflicting information....some say they are shit but yet some say they are good and had no problems
I just wanted to see if anybody here has installed them...and what their experiences were
dont do it to yourself you will really regret it
I Most likely won't - had a chat with a friend...told me more about them and how much of a hit or miss affair they are..
But I'm really stuck in terms of what I should do in terms of upgrading the turbo
Choices are:
Option 1 (sounds like the cheap option - but seems effective)
- just basically service my current turbo and change the wheels to steel and possible change the actuator
Option 2 (what my friends suggested to me)
- high flow to GT2530 or GT28RS internals
What do you think?
On a Stagea i would go one of two upgrades.
1/ High flow your current turbo using a sierra-sierra combination. ie: using the front and rear wheels off a sierra cossworth turbo and also upsize the rear housing. I made 274rwkw@15psi, but any more boost didn't really improve the power much, so i dare say 270-280rwkw is probably max for this combo.
2/ Fit a HKS GT2835ProS or even a Garrett GT30R.
The GT30R should see just over 310rwkw, just do a search on both turbos, both have great results.
Just another note: The Stagea is a heavier car than the Skyline, thus will load up the rb25 more, resulting in boost spooling up a little quicker. Also the 4wd will make the surge in power, once on boost, easier to handle.
it has been covered to death in forced induction which sometimes makes it hard to find due to the number of "its been covered a million times" posts.
if you want a reliable and reasonably priced upgrade then the most reliable choices are:
1. GCG hiflow $1800ish straight bolt on. wait till your turbo fails and then send it away to be rebuilt with all new internals.
2. HKS GT-RS $2300ish straght bolt on. seems to work slightly better than the GCG hiflow but it is a very close thing additionally you can sell your old turbo for $300-500
both of these turbo do not require a new dump pipe and as stated are bolt on both will make around 250rwkw +/- 20kw.
3. HKS 2835 ProS $3000 (kit with all the bits oil water lines, short dump etc)
4. GT3071 or GT3076 but will require oil water lines and a new dump and possibly some intake modifications.
there are lots of other options but consistently these seem to come up with predictable and pleasing results.
other cheaper turbos have variable results so why take the risk?
nothing wrong with a good quality oil AND water cooled journal (bush) bearing high flow with highly ported intake and exhaust, with good matching steel wheels
:worship: thats around $1200-$1500 (mine was under $800)
or same as above, but ball bearing GCG, $1800
As most guys know I use my Stagea pretty much daily and I tow the race car with it. So I needed a turbo upgrade that would give lots of torque and handle the temperatures generated by 4 tonnes (Stagea + 2 people + trailer + R32GTST + spares and tools). I wanted to keep the rpm down at the same time, as using lower gears generates a lot of heat in the auto trans, which has an upgraded cooler of course. I didn't want to have to rev the engine to get the boost to make the torque and outright horsepower was not a consideration. I also wanted 100% reliability, it's not much fun if the tow car turbo dies on the way to or from a race meeting. Plus it had to be a half day bolt on solution, I don't want to spend time on the tow car that would be much better spent making the race car faster.
So my choice ($1750 on the Group Buy) was a GCG Ball Bearing high flow. However I used an RB20 turbo to take advantage of the smaller compressor cover for faster boost build. It fits the above criteria perfectly, makes a bar at under 2,000 rpm, went on in a few hours, with zero mods and hasn't given one ounce of problem.
Cheers
Gary
So many options, so many different ways to attack it...thanks for everyones input so far.
I'm total newbie when it comes to stuff like this (as this is my first turbo car) and for me it's going to be first of many changes done on my car (gotta do exhaust system, intercooler (which i'm in the process of modifying - no need to go into it as i have stated on here before), suspension (hopefully SK's group buy is still going when i've got enough cash) but the turbo is the first thing that needs to get done as I have a feeling that's the first thing that is going to go. Basically I want to get my car around the 180 - 200kw at all fours with very minimal mods
Quick question what is the flange on the stock Stagea turbo (so I know what to look for if i'm going to buy another turbo) also (though it may sound silly) should you buy a new turbo or a good - very good second hand turbo (obviously get the turbo serviced to make sure it's not completely wrecked)
jason
you can get about 200rwkw +/- out of the stadard turbo which is is pretty close to what you are asking for.
i wouldn't rate the turbo as the first thing to do. why not save your money for a little longer, get the rest of the gear, tune it, drive it then see how you feel.
given the price of the new turbos for your application i would be buying new.....unless i personally knew the history and the owner. (something i just did btw)
T3 flange, and a world of options between a grand and two in cost
then factor in tuning
some sort of ecu whether that be piggyback or standalone. Good luck with that !!!
you can get 180kw with the neo engine/turbo/smic. grab a z32 afm, a nismo fpr, a bosch 040 fuel pump, a safc neo and a sitc (or emanage in lieu of these 2 piggybacks), full 3" exhaust, auto trans cooler and shift kit, sk's bilstein shocks and whiteline swaybars and bushes, braided brake lines, and you'll have a good stagea thats an allround wagon. go, stop, and cornering. hiflow the neo turbo (make use of the bigger exhaust housing that you have in the S2 over the S1) and there is 200+
about 5k tho all up ^
ATP near chady if you want a cheaper bush bearing turbo, or Eastern Turbochargers in bayswater if you want a BB job. Kev at eastern knows his shit, and would most likely match the GCG price. I know AlexCim's GCG was laggy as f**k. and it was tuned by a decent tuner. Also, if you go local, its easier to sort things out.
Access Autoworks(trade place, vermont) are Nismo dealers i'm pretty sure, and they would be able to organise the S-tech suspension package.
Better than being like so many other members and waiting for months on products and refunds from a 'trader' on here, with no return to e-mails/calls.
My experience has been exactly the opposite, I have had 4 x GCG ball bearing high flows all tuned by a crappy tuner (me) and laggy is most certainly not a word I would use, not even remotely close. Against any measure they have all been super responsive. The Stagea makes well over 0.5 bar from a standstill against the torque converter at 1800 rpm, on l;aunch it leaps up to 1 bar instantly, that's a pretty good indication of the total abscence of any slowness of boost build.
Don't always blame the turbo, sometimes it's not the real cause of the problem.
Cheers
Gary
PS; that also applies to blaiming the middle man (the poor old Group Buy co-ordinator) who does it for nothing.
Cheers
Gary
gary, my slide turbo is exactly like that
awesome response, slightly slower off the line Id imagine compared to a rb20 housing, but nevertheless for $800 wow what value
Cheers
Gary
gary, could you or matt please get in contact with me? i can appreciate that you dont get much besides a job out of this(eg, Jamex now have a market for your products) but 4+months of avoidance isn't great customer service.
Cheers,
Ryan
Cheers,
Ryan
Hi Ryan, there are 275 PM's in the inbox and not one of them is from you, so I have no idea what it is that you want. So I sent you a PM asking exactly that.
Cheers
Gary
    • Thanks! Will get it looked at before winter 🥶 other than that she's a mint ride love it aye
    • FWIW a lot of the local owners that do a big build tend to have cars that are perpetually broken.
    • I just got this system but haven’t installed yet I got a Moroso sealed box (defect reasons) which will be set up same as their pic The quality is high grade, the correspondence I had with the owner (former head designer for Rockford Fosgate) was unbelievable, guiding me with what I needed. Even told me not to buy some things as it could be sorted in a different way at his loss. Just a bit of a bite with the exchange rate and don’t purchase gear in 1 hit that goes over $1,000 au, lol I forgot!
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I eliminate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for? (Apple car play? Android air play)? so If I swapped head units to save using a band expander, I’d likely lose those better features to have an oem Unit operational. Better to use a band expander and retain AirPlay options and newer version of head unit     provably best to band expand it, and focus on the nav unit. th isn’t  a big deal/ would be cool to have it working  from what I can tel we use a PAL Signal and Japan uses a NTSC signal  I don’t know if there’s a co better or if the screen only reads NTSC, or if it’s the tv module that needs replacing… no big deal don’t need it but more of a curiosity thing on that!   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
