wow, thats cheap
ask the seller if it is water cooled as well as oil cooled?
Wow, That isn't bad for the price!
I take it you are the winning bidder? (not you Tangles, but Jase)
  • Replies 45
*Update*
I didn't buy the one that Tangles and I looked at from ebay. found out that the wastegate has been welded shut and required an external wastegate.
I have purchase a Blitz SBC iD3 Spec-R Boost controller and a second hand turbo from ebay. HKS GT2535, has no shaft play and has only done 3000km on it. It's come off a R33 GTS-T and was boosted to about 10 psi. Also i get the dump pipe and all the lines as well. i'm not going to use the dump pipe(it's one of those screamer type dump pipes) should get it in about a week.
pics
post-34764-1219826366_thumb.jpg post-34764-1219826374_thumb.jpg post-34764-1219826379_thumb.jpg post-34764-1219826385_thumb.jpgpost-34764-1219826392_thumb.jpg post-34764-1219826399_thumb.jpg
  • 2 months later...
*Update*
Hey BigDirtyJase how'd this work out?
Well I got the boost controller installed and that is running well...a few spikes in auto mode but then again test driving in rain (and on a road that's private property) doesn't help. Just need to play around the settings a bit more
I haven't installed my turbo and my cooling pro stealth intercooler yet as I have ran out of funds (rego and insurance time...yay...not) but I will definately have them installed by the new year...The only thing I saw today which its a concern is the nipple on piping from the bov is cracking or cracked and needs to be welded up again (atm the piping is blocked and I don't know if i need to route it)
    • Yeah, well, it's not as though anyone is ever going to buy one of those noisy f**kers and put it into a new installation when there are better pumps that are near silent for less money from Ti.
    • I'd suggest having the engine builder listen to it, especially if they assembled it, and minimise how much you run it in the meantime. It may have a serious issue like a big end bearing from the description and I assume the rebuild was not cheap
    • Quite right, typing without checking, it is an 023 which was effectively the replacement for 040 (not that I could find either of them on the Bosch motorsport AU site), and it has a mesh inlet at the bottom of the pump rather than a separate filter
    • Hmm. I should have thought of the clutch bleeding issue. It should be #1 thought for "can't select gears". As to "sounds like the top".....have you actually gone out with the stethoscope and tried to pin it down any more than that? And, buy or borrow a timing light, and set the timing properly.
    • I donโ€™t really have any ideas how to set the timing on the CAS ๐Ÿ˜‚, sounds like the top, sounds like it maybe misfiring as well as ticking,ย  got the box sorted ๐Ÿ˜Œ, must of been a air bubble on the clutch side
ร—
ร—
