32 Gtr Grinding Gear Change
Tamrb26
 Share
Hi peeps, my gtr gear change 1,2,3,4,and 5 has been grinding two days ago. Sometime i find it hard to get to gear one.
I notice the grinding gear change only happans when i drive for more then 1 hour.
So what could it be? do i need to change gearbox oil?
if so, what kind of oil should i use and how do i change the oil.
THANKS GUYS!!!
Sounds like it could be clutch related issue if its every gear and also engaging 1st. Get your clutch checked out.
Does the clutch feel OK? Check clutch fluid level.
Make sure the clutch hydraulics are in good conditon and getting good travel at the slave cylinder.
You can check gear oil but i doubt it will be the cause.
Deren
Deren
Thanks for the reply deren. I dont think it could be the clutch, press the clutch down and change gear is fine, but once i drive pass 1 hour thats when it happans to grind or hard to shift. After rest the car for 10min, back to driving again everything seem to be fine after 1 hour same sht happan again. :rofl:
 Share
