Make: 1986 holden vl turbo berlina
Model:
Milage:
Transmission: 5 speed
Colour: light blue/green
RWC supplied? no
Currently registered? no
Price: 14k firm
Contact: 0412285096 msg me please
Comments / Modifications:
rebuilt block
new dizzy
new spark plugs and leeds
new crank angle sensor
vlt lsd 3.45 gears
sss low king springs
3inch mandral bent exhaust off the turbo with high flow cat
5 speed box
1100kg ceramic 5puk clutch
gtr lightened flywheel
battery relocated to the boot
new starter motor
ss high mount mainfold
600hp turbo
38mm external waste gate
pod filter
na runners with a polished nizpro plenum
xf throttle body
gtr injectors (440cc)
adjustable fuel pressure reg (with guage)
walbro 320lph external fuel pump
oil catch can
hybrid gt spec intercooler with 3inch polished piping
turbo smart mega sonic blow off valve
shaved head
acid dipped head
A.R.P head stud kit
roller master fully adjustable cam gear
new inlet and exhaust valves
cometic triple layer head gasket
wade 1147c cam (very very lumpy)
microtech lt12s computer
new steering wheel
boost guage
e-boost and turbo timer (not hooked up yet)
ive spent over $20,000 on this car!
everything i have mentioned has travelled less then 100km and has had 3 dyno runs..
its tuned to 312rwhp at 12psi but the car made 455rwhp at full boost!
Hi Guys, these are the only pics i have right now - they were taken a couple of months ago though, but at least you get the idea of it! let me know if you need any more info or want photos of anything specific. Cheers...
Edited by lovelessnator
it spun the big end bearing so thats why it now has a new rebuilt block and the car has been off the road for the last 2 years now.. im an apprentice so im not making the best of money and ive just come to a dead end and lost interest in this car (unfortunatly)
the car has been in my family since it was brought from the factory and very well looked after, there is no one in my family that wants to continue on with it so ive decided to part with it! ive also just brought land so i need to be putting my money into that instead of my toys..
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
