1989 MX83 Toyota Cressida GLX
  • White exterior, plush blue velour interior
  • 3.0L six (7M-GE)
  • A340 electronic auto
  • Climate control aircon - regassed ~2 years ago, farken FREEZING
  • Tinted windows - good quality T35 metallic tint, professionally done ~3 years ago
  • 6 CD Pioneer stacker
  • ~313,000km
  • Comfy as!
  • Selling UNREGISTERED (ran out of rego a couple of weeks ago)
  • Car is located on the north side of Brisbane
  • $1500 ono - make me an offer!
Reason for sale
We have two other cars and a bike so I really don't need the Cressida any more, and it's killing the grass :rofl: I bought the car a few years ago as a comfy commuter and it did the job beautifully, but we've moved onto a newer daily driver and could use the proceeds from selling the Cressida around the house.
Other info
It's like riding a pillow - it really is the most comfortable car I've ever driven. It won't set the world alight but that's really missing the point - that said, they do suit JZ engine swaps extremely well, making it the ideal sleeper!
It isn't perfect though, the paint on the roof is a little cracked and it has a miss at idle. I haven't done any checking so it could be as simple as a fouled plug or a dead plug lead. I also suspect it has a small intake leak, which I haven't looked for. The auto works better when it's warm - when it's cold it sometimes sticks in 1st gear. The tacho doesn't always work (just a loose connection as sometimes a tap on the dash will fix it) and a previous owner broke the clips holding the section of the dash below the steering wheel on, it's currently held on with tape as I've been too lazy to find a new one. The steering wheel needs replacement as the foam has separated from the wheel.
To be honest it probably doesn't need much done to it, but I don't have the time or motivation to do it. As a result, you get a very cheap car that needs a little work. All it should need for roadworthy is a steering wheel, fix the miss, and secure the dash panel below the steering wheel. As far as I know, everything else is legal. It was registered up until the 11th of July and I haven't renewed it as I don't drive it much any more.
Price is $1500 ono as-is, unregistered. You'll need to bring a car trailer, tow truck, or trade plate to get it home legally. If you're quick I may be able to assist with cheap towing.
Contact
I can be contacted by PM or you can just post in here, or you can PM me for my phone number.
Pics to follow
Edit: SOLD!!!
Heh thanks Adam ;)
I need this gone guys! Make an offer!
My brother is a towie so I can possibly help to organise cheap towing for the buyer too
  • 3 weeks later...
I can't believe nobody wants a cheap luxo barge!
Don't be put off by the imperfections, I think you'll find that a lot of second-hand cars have problems, the seller just doesn't tell you about them. I'm being as up-front as I can with this sale, so you shouldn't get any surprises.
Come on fellas, you know you want it, make me an offer, I need it gone!
G'day.
Have you thought of putting this ad on jxz100.com? Lots of the Chaser boys like these old girls.
And yes with a 1JZ or 2JZ you have possibly the ultimate sleeper.
Tell you what, I will throw a link in the for sale forum over there for you.
I used to drive a R33, but now I have gone over to the dark side...
cheers
  • 1 month later...
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
