I just bought a kenwood headunit KDC-MP4039 it's a cheapy but i needed something asap now my question is it has a front AUX port for ipod or other media player.Now the only portable player i have is my nokia 6110 is it possible to connect this to the head unit some way. I know there is a 3.5 double ended plug available would this do what im after or would i need a proper nokia one. I dont want to use the phone thru the stero just have it as media player .Any help much appreciated thanx
https://www.sau.com.au/forums/topic/229849-n00b-question/
if your phone has the standard 3.5mm headphone hole then yeah any double ended plug will work as it's just like your phone is an mp3 player or other media device.
if not, if it has that funny-shaped nokia plug (like my 6288 has) then you'd obviously have to get a cord that suits both ends.. i reckon you'd be best off contacting nokia in that case.
Hope this helps
Ric
https://www.sau.com.au/forums/topic/229849-n00b-question/#findComment-4039433
yes it will work but dont be anoyed when you plug it in for the first time and it doesnt work lol.youl probly have to go into the menu on the kenwood CD player and turn on the AUX input as most of them have the function turned off from the factory.
if you need help on how to do this ether read the manual or just ask me on here :worship:
https://www.sau.com.au/forums/topic/229849-n00b-question/#findComment-4039838
Ok got the plug and got it to play music but it is not ideal song selection and play/pause is done thru the phone is there anyway i can get to use the head unit for skipping songs and play/pause the instruction that came with it are avaerage it is mainly designed for ipod me thinks.
https://www.sau.com.au/forums/topic/229849-n00b-question/#findComment-4040171
This is my problem i asked for the usb version of the same unit which was $80 dollars cheaper it wasnt till got home and installed it all some 3 hrs later i realised he'd given me the wrong one. He charged me for the correct one but gave me the wrong model i cbf taking it back out again tho so looks like im stuck with it,im off burn some cd's then :P
https://www.sau.com.au/forums/topic/229849-n00b-question/#findComment-4040402
This is my problem i asked for the usb version of the same unit which was $80 dollars cheaper it wasnt till got home and installed it all some 3 hrs later i realised he'd given me the wrong one. He charged me for the correct one but gave me the wrong model i cbf taking it back out again tho so looks like im stuck with it,im off burn some cd's then :wave:
take your car/receipt back to the place you bought it, and staple the receipt to the guy's forehead... like seriously. as if you get ripped off 80 bucks and then have to put up with burning cds and them going all over the joint in your car...
https://www.sau.com.au/forums/topic/229849-n00b-question/#findComment-4041121
Nah it was the other way around he charged me $199 for the headunit but he gave me the the $289 one it;s just the cheaper one had usb but the one he gave me doesnt, i dont know why the one he gave me was more expensive tho must be something for the $90 price difference.
This is the one he gave me
Kenwood KDC-MP4039 -$289
This is the one i wanted Kenwood KDC-MP5039U-$199
The U designation is usb port in front face.
https://www.sau.com.au/forums/topic/229849-n00b-question/#findComment-4041430
highly doubt it.. if ur gonna do that just use ur phone to transfer the music
or plug mp3 player in it now.. there very cheap these days
its good everytime you download a single song you dont have to burn a hole new cd to listen to it in the car.
https://www.sau.com.au/forums/topic/229849-n00b-question/#findComment-4043173
    • Yeah that's true, but idk. Only a 6 month lifespan seems a little short. Oh also, is there a preferred way to send images? Like any sites? I'm used to just being able to upload them lol
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
