hello all, my r33 keeps blowing park fuses ive searched the web for a wiring diagram but all i can find is engine management and computer related stuff ive downloaded the nissan r33 engine service manual but thats no help, does anyone know where i can get the diagram i need , does anyone know if r33s have a common fault with parkers? i had to ask you never know. :rofl:
https://www.sau.com.au/forums/topic/229862-r33-wiring-diagram/
Oh... do ur inside and outside ones work? or no park lights at all? to they turn on when u put your low and high beams on? Could be the switch
no park lights at all only high and low, i have brake lights thats all,i have front and rear blinkers,i unpluged the front and rear lights also the number plate lights but when i turned the switch on the fuse blew instantly also the buzzer that tells you the door is open dont work :worship:
Just looked through my manual but the same no wiring other than engine controll. If you like you can bring the car around to me and I can try and find the fault for you, could only be in a few spots.
Cheers
Ross
i would like that :sick: where do i bring the car to?
  • 4 weeks later...
i fixed the problem,and yes it was the earth to the stereo ,i fitted a stereo a few weeks before but the problem only just recently happened :)
hey mate i had a similar problem with my fuses blowing all the time found out that it had to do with the stereo earthing the wrong wire have a look around there
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
