hello all, my r33 keeps blowing park fuses ive searched the web for a wiring diagram but all i can find is engine management and computer related stuff ive downloaded the nissan r33 engine service manual but thats no help, does anyone know where i can get the diagram i need , does anyone know if r33s have a common fault with parkers? i had to ask you never know. :rofl:
https://www.sau.com.au/forums/topic/229862-r33-wiring-diagram/
Oh... do ur inside and outside ones work? or no park lights at all? to they turn on when u put your low and high beams on? Could be the switch
no park lights at all only high and low, i have brake lights thats all,i have front and rear blinkers,i unpluged the front and rear lights also the number plate lights but when i turned the switch on the fuse blew instantly also the buzzer that tells you the door is open dont work :worship:
Just looked through my manual but the same no wiring other than engine controll. If you like you can bring the car around to me and I can try and find the fault for you, could only be in a few spots.
Cheers
Ross
i would like that :sick: where do i bring the car to?
  • 4 weeks later...
i fixed the problem,and yes it was the earth to the stereo ,i fitted a stereo a few weeks before but the problem only just recently happened :)
hey mate i had a similar problem with my fuses blowing all the time found out that it had to do with the stereo earthing the wrong wire have a look around there
