hey ppl,
even with money in hand, i am still having so much dilemma in getting which one....
Have already look at the force induction section and searched. Just need abit more help on some prices of custom fabrication in Perth.
I have been looking at the hks gt2835 turbo kit.kits only comes with 0.68 A/R. some says that people that went for gt2835 0.68a/r will regret later as it will run out of puff later on (if going for more power).
Was wondering how much would it cost me if i was to get the gt2835 turbine with the 0.76 A/R fabricated to suit rb25 neo?(Perth prices) eg: lines dump pipe etc etc.
or go GT30?? :worship:
Thanks in advance!
CHeers
https://www.sau.com.au/forums/topic/229891-turbo-dilemma/
Probably best answered in the FI forums.
Anyway, I'll answer as I am actually in the process of having one of these (2835 pro s) fitted (tomorrow!).
It depends on how much power you are chasing and what your goals are in the end? If you just want a quick responsive street car, going any higher than this will produce higher hp, however the cost may be lag.
But, if you are producing something for track/drag racing at high speeds then I can understand your need for a larger possibly high mounted turbo.
I.e. the reasons I chose this turbo was because I intend to own a quick street car that wont require me to rebuild the engine, will be responsive and wont attract unwanted police attention. I am aiming for 250-280rwkw from this turbo.
Depends what you want to do??? :worship:
Cheers
https://www.sau.com.au/forums/topic/229891-turbo-dilemma/#findComment-4039881
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
