  • Replies 82
Install seat and seat belt and it can be driven.
But before it gets driven it will get some semis and bolt on flares and a bit more weight reduction and some tidying up.
Still deciding whether to leave the torsen diff in it for it's first outing or put my mech center in now.
Edited by BHDave
Excuse the n00b question Dave, but whats the diff (hehe) between the two diffs?
And was that dumhed's?
Ando - we can easily fix that - go get some cans pf spray paint :blush:
Do you see now why we said your car was too pretty to be a nugget?
yeah, it was dumheds.
the torsen is a really nice street diff, they are great when you have weight over both wheels and provide good drive (so no single spinning the inside like a shagged viscous) but once you unweight or lift the inside wheel it goes open as you apply throttle.
with my penchant for bouncing off kerbs i can see it not working for me too well.
Also dumhed had issues with it spinning up on med to fast sweepers so he installed the big rice wing to keep a bit of load over the arse end which helped. That didn't come with the car so it will have that problem if i don't change the diff.
Ha ha yeah i agree.. but i got sick of having a pig of a car with the old Cefiro... the blue nugget is a bitz of both... noice but trackable..
Nice purchase! That car is loud and quick.... Go get a Fully GT spec wing from Jjap LOL You know you wana!
tmb is waiting to see how the new light weight bonnet turns out.
If it's good i'm sure he will give you the contact details.
Both boot and bonnet require pins so no good for street cars....
Eventually it will get a turbo.
I already have the 3071 off the old car and i have a low km s15 engine that i picked up as a partial trade on some bits.
So there's a new rear housing, manifold, cams, springs, rocker arm stoppers, gate, and head gasket to get into it before install.
The car already has an s15 pfc installed so it's an easy swap.
short term is get some flares, get some new semis on my 17x9 +25 sterns, tidy it up a bit and drive it.
Not so short term is full re wire, more weight reduction, and some paint.
Engine is a long term one. So about 6 months or so depending on money :)
The r32 was scary. This thing will be in a different league once it gets a turbo. The previous owner has already got it into the 9's as it stands and i used to dive past it on the straights like it was standing still....
My old GTR diff does that but you can drive around it. Just have to drive better. (I'm not saying I do - just that I can tell the difference between getting a corner right and getting it wrong.)
bah! I'd rather cover for my lack of ability by jamming a better diff in it at zero cost :D
Sound like you need to invest in a nismo clutch pack bob :O
That's the way. I would.
One day, that would be nice, in the meantime I just try to drive smoothly.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
