One weekend, 4 states, and over 3,400kms later ... I'm back in little old Adelaide. I'm so tired of driving its not funny :D
Main purpose of the trip was to catch up with friends in Wagga Wagga and do a bodykit swap with Pintaline in Canberra.
Great 4 day weekend for me :D ... now I'm rooted. I'm off to bed shortly.
So what did everyone else get up to on the weekend? What did I miss :D
https://www.sau.com.au/forums/topic/230002-im-back/
ohhh that's no fun :huh: Well the post whores (me and Adrian) were in Blanchetown for the weekend, so SAU was fairly on-topic :)
ha thats was you, i was on paisley island near the caravan park at blanchetown heard you cruisin up and down all weekend
heard but didn't see... question, was it 3 or 4 RBs my bet is 3 and something else, sunday morning im talking bout
https://www.sau.com.au/forums/topic/230002-im-back/#findComment-4043896
nope 4 rb's, Bunny33's R33, My R34, Rad32's R32 and In Heaven's R32. Yeah we were pretty loud lol, don't suppose you saw the smoke of the fire we had cranking? :blink:
https://www.sau.com.au/forums/topic/230002-im-back/#findComment-4044949
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
