Just a general question... where does one go to get a good quality v-band clamp and not one that looks like it's going to bend / snap when tightened up?
I don't mind spending a bit of money so even if it's completely overkill, throw it at me.
I recall someone on this forum once posting up a photo of a billet clamp of sorts (made for aircraft I think), was purple.
Thanks in advance
S
https://www.sau.com.au/forums/topic/230020-v-band-clamps/
Thanks for the response...
Yeah they're the ones that were posted before, but now I see them again - they're not what i want. I am in need of some quality V-Band clamps. Do they make something similar but in V-Band format?
Might get a few of those Wiggins ones for elsewhere!
Thanks bud
https://www.sau.com.au/forums/topic/230020-v-band-clamps/#findComment-4042058
Wouldn't have thought a wiggins clamp would pull down hard enough to be used on a radiator hose. They use flanged pipes and orings, they don't use compression to seal they use the orings hence their flexibility?
I'm sure if they can hold intercooler pipes they can hold a radiator hose
cooling systems only get to ~1 bar
Yeah great - got quoted about $500 for a 4" Wiggins clamp kit today... that's ONE CLAMP... does anyone have the number for an oil tycoon in Dubai? My best friend just got fired...
told you they were dear as poison LOL
https://www.sau.com.au/forums/topic/230020-v-band-clamps/#findComment-4044814
Adel Wiggins Flexible Tube Connectors, known familiarly as Wiggins Clamps, provide an ideal method for connecting and sealing two tubes.
They are available in aluminum with a stainless two-finger latch, and are frequently used for vacuum lines, water lines, and turbo intake plumbing.
All are qualified to AS1650 and MIL-C-22263 specs., and are tested to greater than 125 psi. operating pressure, at temperatures up to 450° F depending mainly on the o-ring material.
https://www.sau.com.au/forums/topic/230020-v-band-clamps/#findComment-4046021
Ok deleted the last post and will try again. You can't just buy a wiggins clamp and slam it on over your silicon joins/hoses, there not that type of clamp. They can only be used for metal piping as you need to weld on the ferrules. Yes I know you can use them for pretty much anything. Had a quick look around for some pics to explain what I mean.
https://www.sau.com.au/forums/topic/230020-v-band-clamps/#findComment-4046190
same goes for V band clamps. they are only good to join to pieces of alloy or steel pipe since you need to weld the appropriate flanges to the 2 pipes so you can use the V band clamp on it.
V band kit:
another good example of V band clamps and flanges. they are good for IC piping, and exhaust if you have the time and money to install them. :)
https://www.sau.com.au/forums/topic/230020-v-band-clamps/#findComment-4046217
can these be used on radiator hoses and such??
wiggins clamps can
but they are dear as poison
Just sounds to me like your saying they can be used on silicone radiator hoses....
https://www.sau.com.au/forums/topic/230020-v-band-clamps/#findComment-4046218
  • 5 weeks later...
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
