hey all
i got a big fkn problem. I was driving last night and i though id give it a little i was in 4th and got to max boost and before i cud change to 5th i looked behind me and the whole main road (kings rd sydenham) was covered in white smoke. I shat my pants. My car sounds wierd the idle was dropping out but not that much for the speedo to pick up. Now the car wont even start someone said its the spark plugs. If anyone has anyinfo of what it might be cos im also suspicious as to why there is oil sometimes spitting out of my blitz bov and some sitting in the throttle body where the stock bov is? someone from racv said the oil may have gone into the engine caught alight and smoked out the exhaust?
any info would be great cheers
antoni
https://www.sau.com.au/forums/topic/230052-engine-problem/
  • Replies 52
lol relax man just asking lol ive got new spark plugs and gonna do it tonight but yer the oil is shitting me cos ye oil spitting out of it sometimes and when i replaced the intercooler piping oil in the pipes
https://www.sau.com.au/forums/topic/230052-engine-problem/#findComment-4042569
haha bad huh lucky i didnt get busted haha
i checked the engine and is fine the car feels fine when i drive still 100% response its just that one time that smoke came out now the car wont start at all its onli idleing its loosing the plot this morning before work i started the car and it was fine it stalled and wont start the starter motor n shit r fine they r working its just the engine wont spark sometimes it sounds like its about to start but meh it was cold aswell
https://www.sau.com.au/forums/topic/230052-engine-problem/#findComment-4042780
ahk hopefully compression is fine, because the car boost's fine, not one thing wrong with it when it drives. It was just that one time.
But thanks heaps for all the info everyone, if you have anything else by all means let me know.
Really appreciated.
https://www.sau.com.au/forums/topic/230052-engine-problem/#findComment-4042853
nah no noises, my mate asked me last night because he thought it could have been a blown turbo or just damage to the housing. But turbo sounds perfectly fine, no wierd noises and still boosts fine
https://www.sau.com.au/forums/topic/230052-engine-problem/#findComment-4042920
You're not wrong there, you imbecile.
I was driving last night and i though id give it a little i was in 4th and got to max boost and before i cud change to 5th ...
max boost in 4th, and you're going for 5th. On a public street. :wave:
You sir, are an absolute Fu(kwit, the kind we don't need here.
https://www.sau.com.au/forums/topic/230052-engine-problem/#findComment-4042941
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
