Well i have a 1989 r32 gts which has an electronic front lowering lip except it doesnt lower!!!. Its quite strange because when i press the down button i can hear some mechanical crap going on but its not actually lowering.
Today i discovered that if i unplug the left side hydralic you cant hear anything going on at all where as if i unplug the right side you can still hear the left. So im assuming the left side wants to do something but the right is buggered.
Could it be the electrics or the actual hydraulic motor thingo. Has this happened to anyone??
Cheers.
ok stop right there. it's not strange. your car is almost 20 years old. and so is that spoiler.. but do go on...
it goes down at 80-100km/h apparently, so take the car on the freeway, with a friend, get upto speed and tell your friend to hold the wheel while you get out n check.. =D
Cheers.
in all seriousness i would say itd be hydraulic motor, on the left, because it's getting a response in the electrical sense, but on the right side, could be electrical or both... because it's getting neither response from what you're saying
What would you be willing to pay for said motor? They are pretty weighty though, postage would suck.
Yeah i would be looking for a pickup job i spose. thanks anyway!
I haven never seen one post a pic of it :P
lol, yeah i will be first thing tommorro.... so keep your foreskin peeled... i mean eyes!
My Car;
The spoiler pops down at 80km/h.
The Down button will only work if you have the park-brake engaged.
But you said you can hear it making noises as you press the button, so you would have the park-brake pulled up already..
My Car;
lol i watched that on youtube yesterday. Yeah i have tried the down button with park brake both on and off. Also it makes a sound everytime i take the handbrake off. does yours?
if the spoiler is down and the hand-brake is taken off, the spoiler automatically pops back up. Hence why you hear noises
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
