Someone might be able to help me with this one...
Has anyone had to change a name on a title (land) before? Who or what do you have to do or contact?
Also what sort of costs are involved?
Would it be a lawyer and if so would any lawyer be able to do it?
https://www.sau.com.au/forums/topic/230108-changing-name-on-a-title-in-vic/
Thanks Sarah... nah when they originally transfered the title of the house they didnt put my full name on it which means now that im refinancing they cant do shite until it has my full name so i just need it changed. So i dont think i would need to pay stamp duty again on my own house unless you have to when you refinance... altho thats a little stupid. Why pay it again when i havent sold it to myself.
this is the government your talking about, they will get what they can when ever they can.
lol true... its the vic gov too so they will probably just send me hundreds of imaginary city link speeding fines.
your case may be a little different Ni as you just need a typo fixed rather than transfering the property
id call the titles office, tell them your situation and that they're shit! and see what they say is the best way to fix it
ok no worries. cheers Sarah
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
