6x Yoko A048 Semi Slicks, 235/40/18
4 at 80%+ & 2 at around 40-50%
I know a lot of you are after good s/h semi's & they can be hard to find, please if you're interested CALL rather than just PM 'cos I'll be out for awhile tonight & you might miss out.
Cheers
John
0413 615955
https://www.sau.com.au/forums/topic/230112-semi-slicks/
Just spoke to John who is not online atm. $1200 for the lot plus shipping.
Call him if interested.
And I can highly recommend Johns rubber. Very happy with what I got.
https://www.sau.com.au/forums/topic/230112-semi-slicks/#findComment-4044179
Yep, a price would help (Doh!) but as Geoff mentioned, all 6 for $1200 + Del (Approx $60 Bris, G/C, S/C, $90 Syd, $120 Melb, $150 Adel, Perth $210)
A few people have asked about seperating, the answer is a definate maybe but remember, these are advertised elsewhere etc so by the time you make up your mind, they might not be here.......
https://www.sau.com.au/forums/topic/230112-semi-slicks/#findComment-4044715
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
