i decided to put my car on the dyno to see how much power it had.
mods are
standard rb20
gtrs turbo
power fc
550cc injectors
cooling pro fmic
3" exhaust turbo back
do you think my gtrs should make more boost earlier than this?
i have a turbotech bleed valve on the hks adjustable actuator. can i just run the actuator by itself without the bleed valve? what would be better?
here are the air/fuel graph and torque graph
im interested on hearing your opinion's as im not right up with this kind of stuff
https://www.sau.com.au/forums/topic/230121-hks-gtrs-on-rb20/
Max boost at 6000ish rpm? That doesn't seem right man. Best bet, put the car back on the dyno, wire the wastegate flap shut and see how quickly it ramps up boost, if it hits full boost a lot earlier than most likely your wastegate is opening a bit early and leaking off exhaust gases. Maybe invest in an electronic boost controller if thats the case to try and hold the gate shut.
What state are you in? How well do you know your tuner. On the face of things there is something masively wrong with the results you are getting. It could be tune, it could be boost control, could be the CAS. It could be a collapsed catalytic converter.
Could be lots of things, but i would assume your tuner would have given you some feedback on wht you are makign so little power from a 450hp turbo running that amount of boost, and why it is so slow to build boost
interloper runs a GTRS turbo on his RB20 and he was getting full boost around the same time as my HKS2535, both internally standard RB20 motors
Maybe send him a PM and he will be able to give you some more details since he has first hand experience
Oh and I was getting around 18psi by 4,000rpm if I remember correctly, thats with HKS cam gears though
Something is definitely wrong there looking at those graphs...i'd give everything a once over...check for restrictions and leaks all over...perhaps have a look at the wastegate actuator too...GTRSs come with adjustable wastegate actuators yeah? if so i'd start there...
thanks alot guys!
last night i took the bleed valve off and put the line from the front of the turbo straight to the actuator, went for a run, it didnt change a thing, it weas exactly the same as before.
just then i wired the actuator shut, went for a spin, boost up heaps earlyer about 4500 by the looks of it.
so what does this mean? is my actuator falty?
my line is picked up off the nipple on the front compressor housing like the stock rb20 turbo was, then straight to the actuator
what do i do next? replace the actuator?
thanks alot guys, you've been a heap of help
well, ive just adjusted the actuator shaft as far as i could in(shorter about 10mm) that should preload it right?
took it for a drive like that and it still boost's to 18psi and does it slowly like on the dyno graph
mates are putting the pressure on to go external gate, i want to hold off on that in case there is a easy fix for this actuator
im running one of the jjr split exhaust/wastegate front and dump pipes
it cant be the cat converter as there isnt one, and there is no mufflers so i cant see the exhaust being restrictive
and its perfectly ok to pick my pressure line for the actuator up from the nipple on the compressor housing?
Edited by tp1gts2
Yeah mine is on the same spot man so thats cool.
There's two things that i could think of that may narrow it down a bit more.
a) If you can borrow a dump pipe off of some one that is an all in one bellmouth pipe and not a split dump pipe. I had dramas with my split dump pipe and went to an all in one bellmouth one. I remember reading some where that some people have had their wastegate flap "pulled" open by a vacuum caused in the pipe from the wastegate by the exhaust gases flowing past it down near the cat when the wastegate is shut. It's a long shot but you never know.
b) Try an electronic boost controller and see if it can keep the wastegate shut. Have a look for Trents (URAS) thread from a couple of days ago about electronic boost controllers, kind of explains a bit there.
Other than that it seems to be a faulty actuator that has lost its spring pressure or something and is opening the wastegate early. Did you buy the kit new or second hand?
so... my cheapest option would be to chop the wastegate pipe off screamer spec and block the hole left in the exhaust?
other than that going external gate with the stock manifold might be a idea, what size gate would i need for this?
the kit is brand new, had to wait ages for it to get made
the whole idea of my dyno run was because ive got a plazmaman plenum on the way and wanted to see how much difference it makes, glad i done it now, should go heaps better with proper boost and the plenum haha
thanks alot PM-R33, you might be on to something there
Have you tried screwing some extra low and part load ignition advance into your RB20's PFC ?
The std Hitachi RB20 turbine housing and turbine are much more restrictive than the HKS turbine housing and Garrett turbine wheel .
I'd be looking into this first , cheers A .
Before changing hardware i would be talking to your tuner. Having tuned it he should have a feel for why it isnt performing as expected. It coul dbe the tune, it could be the fact he is scared of pushing any more because of the perceived condition of the engine...it could be he simply lacks the talent to tune the thing...Or it could be something mechanical :happy:
From memory the JJR split dump pipe has a seperator plate that is designed to protrude into the cavity if the standard turbo's exhaust housing to keep the gases of the wastegate seperate, you would of had to grind that bit off to fit if the GTRS came with a HKS T3 exhaust housing i would presume, the wastegate flap on the HKS exhaust housing protrudes further than the standard one, therefore it may be hitting metal and not opening fully, the proper HKS dump pipe is designed to allow for this, (see pic)
I would bet that dump pipe is contributing to your problems.
i may have the wrong end of the stick here, but if the flap is not opening enough it will cause higher boost/boost creep & his issue is the opposite.
could be possible the flap is hitting something & not closing properly i spose
Edited by norwest_rumbler
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
    • Discover the best Halal food near you with Maharajaonline.com.au. Our delicious selection of Halal dishes will satisfy your cravings and make you feel like royalty. Try us today and experience the difference!   halal food near me
