Hey guys,
Ive decided to do something really outrageous in regards to a new shift knob for my car and was hoping for some peoples opinions from a design point of view to help make up my mind.
As your probably confused; few weeks ago i had to go and sell some gold oz' but i decided to keep a few for this project.
These gold 'coins' are almost pure and weigh just over 28grams each
First design idea is to use this trust gearknob and have the top molded out of gold rather than the original logo and have my name engraved into it.
The second design is to electroplate the entire knob in gold using something like this nismo shifter but im not quite sure if this is possible.
Anyways I hope for some advice and i will keep posted with updates on progress and pics of the finished product.
-Johnny
https://www.sau.com.au/forums/topic/230123-most-expensive-shift-knob/
from a design point of view wouldn't you need some fluffy dice or shag pile on the dash to go with it... you know like the pimp look... oh wait they call it DUB now don't they...
OK but in all seriousness - I think you would definitely need something to match it in with the rest of the car. say gold rims or gold dash surround or gold handbrake handle, it would need something or it will just look like another stick-on that matches nothing else...
An also think about the fact your going to have your hand on it all the time (no pun intended) and gold plating tarnishes so wouldn't you end up ith a green nob (again no pun intended), you would have to keep polishing it all the time...
Lmao at hand on nob!
Thanks for the replies so far, Im definitely going with the trust design now as its much easier and wont look out of place in the car.
the electroplating is very complicated and im sure will look ridiculous.
oh and the car dosent leave my garage anyways, i hardly drive it and never park it so it should be safe.
hey yeah I forgot about that one, my alloy one heats up pretty bad, and gold is easier to heat up than alloy I believe (please someone correct me if I'm wrong).
I can't imagine it will be easy to do, using the gold that is on a gear knob.
You could always use the gold heat reflective wrap they use on engine parts, wrap all of your FMIC piping and engine bay bits, that way you have a theme happening...
It could look (although i'm not into it at all) if done right I guess... Just don't put flashy leds in it as well...
if it was going to turn a different color people wouldnt wear gold jewellery... and it wouldnt be difficult to clean. if you want to go gold on the gear knob, maybe also try the button for the handbrake? spray the areas around the window controls in a gold colored paint?
Looks like not many people are into it, definitely right though about gold heating up.
Im not using a theme in my car, it will be left stock just with the shifter. Maybe i should just get it turned into a nice keychain.
Well your right gold doesn't tarnish but gold plating does as is what I stated...
Gold plating is difficult to clean as electroplating will come off if your clean it incorrectly...
Gold spray paint? gees that would look classy and unless you did it really well or got it done professionall I can't see it being very permanent. Unless you got them all gold plated (which would come up shiny chrome like gold) which I believe is hard to find people to do in Aust, best place to get gold plating on plastic is in china...
Bronzing studio in castle hill NSW does plastic gold chroming.. have never got anything done there, but it is an option.
http://www.bronzingstudio.com.au
there seems to be something wrong with their site right now though
thats interesting to know....
I can do a stock shape gold/black carbon fiber weave mat centre section. The center piece is clear for about 4mm in depth with the gold black underneath. Black side panels that look like the original. Been doing them a while in various colour combos but nobodys interested in them. Drop me a e-mail to [email protected] and I'll send you pics of a black/black carbon fiber center section one Ive got on my car
  • 1 month later...
  • 4 weeks later...
    • Ok sounds good. Hopefully if I end up changing it to the nismo bushes I don't get that veering issue. I don't think there's a point in lubing up these bushes again. Weird that it it makes just as much noise with all the grease inside it versus without grease prior to removal. Bizarre.
    • Yeah, you don't need camber bushes on stock arms to make a car drive straight unless it's got another problem. F'rigsample, slide the thing into a kerb, bend the front subframe mounts a little....subframe is now twisted, shifted or otherwise in the wrong spot...and you need to do funky stuff with the wheel alignment to get it to drive straight. Maybe a little more caster on one side, or a little more camber. FWIW, I can have my camber off side to side by a half a degree or more, and either way, so more one side, or more on the other, and the car doesn't really want to pull to one side. It will definitely ride road camber differently, and want to track uphill (ie, towards the centreline when on the LHS of a normal crowned piece of road, like it should) or want to roll downhill (which it really shouldn't). But on fairly flat road surfaces, like the middle of a 3 or 4 lane motorway, a half a degree either way doesn't make a lot of difference. I sometimes do quite a few miles with my wheel alignment messed up, because I don't always get a chance to set it right again after a serious dismantling, before I have to drive it to work again. Like, a whole week's worth of daily shuffle.
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
