I never seen this light come on before in my car. ive been told its something to do with the engine. does anyone know the possible causes for the light turning on? what is it indicating i am not sure. i recently had the car major serviced with new timing belt etc. Can anyone tell me possible things that could be wrong to make the light come on and who should look at it to help define the problem?
any advice would be good thanks
https://www.sau.com.au/forums/topic/230131-engine-light-need-help/
get a not-so-blurry photo so we can make out the icon, unless you can describe to us what it looks like otherwise
someone has probably left a sensor unplugged or there is a sensor playing up and it has logged a code in the ecu. u need to contact an auto elec or if u have a tuner that has a scan tool to check what code it has logged. it usually takes 3 times for the problem to log a code before the code is logged in the computer. have u notice if the car has lost power or hard to start or doesn't idle well etc. hope this helps.
cheers for advice..its NA so no boost controller :) lol... yeah im getting it checked monday i did find a link on forums bout this problem it might be. ive been told it could be coilpacks or sensor problem but i will find out at my mates garage. clearer picture is attached..
cheers for the advice! ive been guessing it would be coilpacks but i been told aswell that the light coming on has nothing to do with the coilpacks so getting confused with all the different advice.
Edited by b3za
errr.....when my coilpacks went...one at a time....three times before i ended up getting splitfires.........the engine light came on.......just be careful of "ghost"error coeds when plugging in the ecu to a laptop....sometimes the real problem dosent come up and something else will.... e.g mine came up with crank angle sensor malfunction lots of times when it was a colilpack!
alright well thanks alotfor the advice! i think im convinced to change coilpacks after monday unless something else comes up which i havent heard before but defaintly kept in my mind. i did suggest to my mechanic mate that it most probably is the coilpacks but i shall let you guys know on monday what comes up.
thanks again
thanks again
Lol i remember when i was posting the same question recently. Most of the time that light comes when the coil packs are gone. Also before blowing money on the coil packs check that its not the oxygen sensor because when that goes, you get the same light aswell.
Theres a way to get the error code from your car just using a paper clip. Im sure someone on here can give you the manual on how to do it. Its super simple and super useful.
when my car was losing a coilpack - it would lose a cylinder and then gain it back - everytime it lost a cylinder the engine light came on, and when it gained the cylinder back the engine light would go off (weird huh!!)
anyways i dont think it is a waste of money to go and buy some Splitfires - i gained 7 kW@ :( and in the end the stock coilpacks are gonna die anyway - mainly due to heat and age....in my opinion if i knew that when my first coilpack went i would have gone and replaced them then, instead of going and spending $200 on each coilpack i had to replace (which ended up being three of the buggers)
best thing is to do also is to get it on a dyno and that will tell u if ur o2 sensor has died.
Edited by MissR34
Paper clips at the ready!!!!!
As the document says, turns the ignition to "on" short the two terminals indicated on the consult plug (clipped covertly on the underside of the dash near where your right knee lives), count the flashes, look up the code
diagnostic.doc
Mine was doing similar last night but i have already had coil packs replaced not long ago. The engine light will come on under load in 5th gear but it will only flash for a second.. only any one got any clues?
Edited by Im_RiCK_JaMeS_BiArTcH
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
    • Each to their own I guess  Me, I put just as much time into cleaning inside of the cars as I do on the outside As for getting wet, it is really no different than steam cleaning the carpets at home, apart from the cars carpet dries alot faster than the house, again, I only do it in the hotter months and leave the car opened up for a few hours As I only do it yearly, it is just before I do the diff and gearbox service, so I clean the carpets, then it's up on stands, wheels off, service, clean the undercarriage,  grease the bushings and do a nut and bolt check on everything  Disclaimer: I typically had all the time in the world to kill when I was working 馃ぃ, so spending a full day or 2 cleaning, serving and "looking at stuff" was,  easily achievable, and a fun mental therapy day As for time to kill, I retired last Wednesday, so apart from my physical training, my days are filled with lots of random jobs around the house and garden...."Idle hands are the Devils something something" I am also buying a new house sooner rather than later, I'm actually looking at a potential property tomorrow, I'm looking forward to getting a car hoist as I'm starting to get to old to crawl around under a car, I can only imagine all the undercarriage cleaning and looking at stuff when that gets set up
    • Yeah, I'm not interested in wetting the carpets, and I don't care about brown dirt/dust that lives deep in the pile or underneath. It's not like I crawl around on them in my birthday suit or eat dropped food off them (because there is never any open food in my car). The seats are alcantara (cheap Chinese imitation alcantara, to be sure!) with barely 1" of foam pad behind the surface. That's not getting wet either. Any car that I would be happy to get the interior wet, I would not care to put the effort into.
    • We have one that holds 2.8L of water. On floor carpet that hasn't been touched in 2 or 3 years, will take a minimum of 2 fills of the tank to do a bedroom, and that's going AROUND the bed.   In the cruiser, I used an ENTIRE 2.8L tank, just on the front passenger footwell. But it had some fungus growing, and had been full of mud from being used as a 4WD for many years. I can do that floor again, and it will still pull mud out. However, the water now only looks dirty, not pitch black and leaving full sludge in the bottom of the tank it sucks back into. Oh, and, this is about a $1500 unit.
    • This is mine, works a treat for the cars, suction is good, I use the Bissell clean and protect stuff I have found giving it a good spray and light scrub with the soft brush on the head of the nossle for carpet, and a rub with a microfibre for cloth seats and cloth door trims, prior to another quick spray before vacuuming it up works the best @GTSBoy You would surprised on what it gets out of carpet and seats that actually "look" clean, I recommend that you test drive yours when you have a little time to kill, then post pics of the muddy looking water that I believe you will find
