Hi guys and gals,,,
Item:
R32 GTST Carbon Fibre Bonnet,,, OEM style
6 month
Condition:
Brand New
Price:
- $800 firm (pickup only)
- or Swap with genuine R32 GTR bonnet and GTR grille plus cash my way
To Fit: (What car)
R32 Skyline
Central Coast, NSW
Contact:
PM or Reply here
Comments:
I would prefer to swap my carbon fibre bonnet with genuine R32 GTR bonnet and GTR grille and would love to have them in gunmetal gray colour plus cash my way,,, depend on colour of your bonnet and grille
Cheers
Ford
https://www.sau.com.au/forums/topic/230154-fs-r32-carbon-fibre-bonnet/
Damn i would snap this up only if it didn't have the same 'iron mask' style of the stock 32 bonnet. Could you saw it off XD? Nice looking bonnet though! Gl with sale.
I wouldn't do that mate and here another pic guys
Cheers
  • 5 weeks later...
mate, I have a black GTR bonnet but it has small hail dents over it, though if you are going to respray it anyway it wouldnt matter... if stil interested PM me.
sorry to go off topic man but i'm really interested to know what size and offset is ur meisters as they seem to fit really well and by the looks of it it doesn't look like you've rolled or lip ur stock guards? do they grind at all when turning or going over bumps?
i'm in a similar situation and i wana know how much offset and how wide i can go. thanks man
    • Is that the blue one rpm?
    • Update 2: Today I'm f**king pissed. Some of you probably saw my thread that I opened shortly after joining this forum, "urgently need expert/experienced opinion", in which I discussed the possibility of a porous RB26 engine block which I also found hard to believe. Currently both turbos are out since the shitty braided line that was installed by whoever fitted the GT28 turbos leaked oil onto the exhaust. Today while working on the cam covers to put new gaskets and half moons in, I cleaned the side of the engine block with brake cleaner. Some time later I saw that it was still glistening with oil or coolant so I dried that off. But it was wet again shortly after. Verdict: I'm royally screwed. What you can see here (hopefully, despite shit resolution), circled in red, is a crack above the turbo oil feed. Extent is a few cm long and basically goes from #3 cylinder wall to #4 cylinder wall. It slowly lets coolant through, even without any pressure behind it. I am absolutely dumbfounded as to how this crack even formed, especially since it isn't along the cylinder as it usually is but rather a horizontal crack. Probably a few cm in length. Not sure on how to deal with this issue right now. Most likely, the only true fix is a new engine block, and even a relatively well done temporary fix requires at least a full engine teardown. Neither of those really fit my timetable right now, the car has been in my buddy's garage long enough as it is. I'm open to suggestions, but I'll be looking into ordering a new 05U block soon so I have one ready for the coming year, or whenever the current block inevitably fails fully. (Most likely once the crack reaches one of the frost plugs) I think it'd be a waste of money and time to rebuild the engine with this block. Oh and I found a rust hole on the side pocket of the trunk, which someone covered up with sealant goop, a piece of number plate and bodywork filler. Fun times. So far for every issue we fix we just find a new one that is arguably worse.
    • I have not found this no. I put one back on a couple days ago with no drama. I agree they are tight, but no need to remove anything.
    • That is gates blue racing belt
    • Anyone found gates blue racing to be extremely tight/ almost impossible to install without moving the exhaust gear
