Hi everybody,
I bought my gtst with all the basic mods and its power fc which was tuned for 100 octane petrol. The previous owner says it was tuned on a shell petrol which didnt have ethanol in it (not V-power racing which i dont like as its 20c more), so my question is since if run i it on 98 octane is there something i should adjust on my hand controller to accomodate to the lower octane petrol?
Thanks!
https://www.sau.com.au/forums/topic/230188-r33-tuned-for-100-octane/
Hi everybody,
Thanks!
Well you've contradicted yourself.
Tuned for Shell without ethanol means it was V-Power, the 98
The 100 was V-Power Racing, which had ethanol, and is not discontinued
So based on what you said, your car is already tuned for 98... so if you've been putting 100 in there, you've sadly been wasting your money.
So if you just muddled yourself and you indeed WERE tuned on 100, you will need to be re-tuned for 98. Simple as that
Yeah somehow the previous owner had 100 octane shell petrol in it for the tune, he said it didnt have ethanol in it but he may have been mislead. Who knows.
So a WHOLE retune is required to have the car running optimally?
I'd check the knock levels on the handset first, if the readings are OK, I wouldn't worry too much about it and just get it done whenever [the tune].
Sounds like the last owner didn't know what they were talking about [some confusion over fuels], so it could be that your tune is already OK as it is.
Suck it and see.............
V-Power racing has been discontinued on the gold coast where i am and i suggest in many other places
this thread is redundant
100 octane is standard factory issue.
skylines from factory are tuned for 100 octane cause in japan thats the lowest octane they have....exept diesel obviously.
stick 98 in the tank and alter the timing the timing a couple of degrees.
Knock levels aren't too bad actually, i had some trouble with it before but i think the boost wasn't tuned correctly (liked to spike).
I switched from bp ultimate to normal v-power last week and i havent seen knock over 25.
I'll take it to the drags and see how i go.
Nizmonut, so i retard the timing by the odd degree?
in summer you will notice a raise in knock
Yeah thats definately true actually, summer was when i was having problems....
I'll let you know when i have time to do it, and we can sort something out, thanks for offering to help. (sick r33 btw :()
lol. that is a good one. 100octane is the lowest in japan. I'm sorry mate but that's simply not true. having been to japan many times, and driven cars in a number of different cities (tokyo, osaka, kyushu, chiba, saitama) I can tell you 100octane is pretty much the bees knees. hi-oku blend. regular unleaded there is like 94 octane. good fuel 98 or so, and yes they have hi-oku 100ron fuel too. but no factory car would be tuned un-able to run on 98 or even 96. this myth came about when high performance cars designed to run on 95 or 96 octane fuels were run on fuel in aus that at the time was 90-92 at best. things have come a long way since then and the gap between japanese fuel and australian fuel is not that great.
Is United doing the same thing with their Boost 98?
Unless the car is tuned on the edge, running Vpower 98 fuel shouldn't be a problem. You will get more petrol into the cylinders compare to vpower racing and find that the car is alot richer. You will be down on power as well.
Have you try the freedom 98? It has 10% ethanol as well and is only 2 RON lower than Vpower racing. If knock reads higher with the freedom fuel then pull the timing back by a few degrees until knock reading goes back to normal.
    • haha this shit box doesn't drink coolant, for now       Let me guess, they make heaps of power, use the car for straight line driving and don't care about noise
    • They’re so great that I know of someone pulling one out to go back to a sequential
    • Hello everyone. I've recently started the research into R34 GTR front bits and running into eye watering prices. On the plus site it looks like some places make 'replacement' fender liners for these cars. At eye-watering-but-less than stock prices. I also noticed there's plenty of diffuser options available too. What I would like to know is if my following assumptions are correct. 1) The OEM guard liners are actually only 'half' the liner. They go together with the OEM brake vents which are a separate item which looks to be quite a large 'panel' that is part of the liner. The GTR bumper has bolt holes along the front. I assume the ones in the vent correspond to the ones the OEM liner does not have (circled?)   2) The V-Spec front diffuser supplants the brake ducts in the above item. I am assuming these still work with the guard liners as there's no alternate part that I'm aware of. I don't see how they go together, so I'm making the assumption that they have to, somehow. I know the center splash guard is different on the V-Spec (and is the price of the damn diffuser alone). How does the liner interact with this? 3) There's alternate front diffusers that do away with it all. Annoyingly, a lot of the clones and CF different ones... have no brake ducts on them. I like the idea of them though. My brakes get hot on the track. These alternate diffusers are a lot cheaper than plastic splash guards. I'm assuming you don't have to/aren't supposed to remove guard liners to run a diffuser. I suspect that quite a few people actually do not run the guard liner because with a front undertray you're getting a lot of 'splash' guarding anyway, and most people remove liners given they're probably running a pretty aggressive setup with a diffuser at the front. It would also be nice to know if anyone has ever run the 'reproduction' guard liners and know whether the fitment is OEM quality or "OEM Quality". Example: https://www.ebay.com.au/itm/356254671561 https://carbonetics.net/products/nissan-skyline-r34-gtr-plastic-front-wheel-arch-set Is this knowledge still around?
    • Really, effort is pretty low. You hand fistfuls of cash over to someone else and pick it up when done...   And at least this shitbox isn't drinking coolant right?
    • And most chargers that most DIY people own would put bugger all power back into the battery between cylinders. I've always done it with jumper packs/second battery connected. And that's on any car.   Because race car, and wanting the lightness.  At least in an R33, putting a bigger battery in can at least help shift the weight balance backwards
