Hi everybody,
I bought my gtst with all the basic mods and its power fc which was tuned for 100 octane petrol. The previous owner says it was tuned on a shell petrol which didnt have ethanol in it (not V-power racing which i dont like as its 20c more), so my question is since if run i it on 98 octane is there something i should adjust on my hand controller to accomodate to the lower octane petrol?
Thanks!
https://www.sau.com.au/forums/topic/230188-r33-tuned-for-100-octane/
Hi everybody,
Thanks!
Well you've contradicted yourself.
Tuned for Shell without ethanol means it was V-Power, the 98
The 100 was V-Power Racing, which had ethanol, and is not discontinued
So based on what you said, your car is already tuned for 98... so if you've been putting 100 in there, you've sadly been wasting your money.
So if you just muddled yourself and you indeed WERE tuned on 100, you will need to be re-tuned for 98. Simple as that
Yeah somehow the previous owner had 100 octane shell petrol in it for the tune, he said it didnt have ethanol in it but he may have been mislead. Who knows.
So a WHOLE retune is required to have the car running optimally?
I'd check the knock levels on the handset first, if the readings are OK, I wouldn't worry too much about it and just get it done whenever [the tune].
Sounds like the last owner didn't know what they were talking about [some confusion over fuels], so it could be that your tune is already OK as it is.
Suck it and see.............
V-Power racing has been discontinued on the gold coast where i am and i suggest in many other places
this thread is redundant
100 octane is standard factory issue.
skylines from factory are tuned for 100 octane cause in japan thats the lowest octane they have....exept diesel obviously.
stick 98 in the tank and alter the timing the timing a couple of degrees.
Knock levels aren't too bad actually, i had some trouble with it before but i think the boost wasn't tuned correctly (liked to spike).
I switched from bp ultimate to normal v-power last week and i havent seen knock over 25.
I'll take it to the drags and see how i go.
Nizmonut, so i retard the timing by the odd degree?
in summer you will notice a raise in knock
Yeah thats definately true actually, summer was when i was having problems....
I'll let you know when i have time to do it, and we can sort something out, thanks for offering to help. (sick r33 btw :()
lol. that is a good one. 100octane is the lowest in japan. I'm sorry mate but that's simply not true. having been to japan many times, and driven cars in a number of different cities (tokyo, osaka, kyushu, chiba, saitama) I can tell you 100octane is pretty much the bees knees. hi-oku blend. regular unleaded there is like 94 octane. good fuel 98 or so, and yes they have hi-oku 100ron fuel too. but no factory car would be tuned un-able to run on 98 or even 96. this myth came about when high performance cars designed to run on 95 or 96 octane fuels were run on fuel in aus that at the time was 90-92 at best. things have come a long way since then and the gap between japanese fuel and australian fuel is not that great.
Is United doing the same thing with their Boost 98?
Unless the car is tuned on the edge, running Vpower 98 fuel shouldn't be a problem. You will get more petrol into the cylinders compare to vpower racing and find that the car is alot richer. You will be down on power as well.
Have you try the freedom 98? It has 10% ethanol as well and is only 2 RON lower than Vpower racing. If knock reads higher with the freedom fuel then pull the timing back by a few degrees until knock reading goes back to normal.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
