Yep thats right they don't make one for the R32 GTST.
AP Engineering modify an existing PowerFC to suit the R32 GTST RB20DET.
From Japan inc. freight costs you are looking at around 1500 inc. gst.
Apparently ECU's dont attract a stamp duty.
Thanks for your enquiry.  Pricing information:
APEXi Power FC RB20DET: 95,403 yen
Shipping: 2,500 yen
TOTAL: 97,903 yen AU$1271
From our experience in Australia, the import system works as follows:
Cost of products + 15% (maximum) import duties + cost of shipping + 10% GST.
Note that for some parts such as engine management, there is 0% duties and 3% for turbos.
An email I received from Greenline.
lol what crap am I talking about...
Try to order a APEXI R32 GTS-T PowerFC No can do they don't have them in production and never have. AP Engineering mod them to suit the R32 GTS-T
AP Engineering Power FC RB20DET: 95,403 yen
Shipping: 2,500 yen
+ 10% GST - $127.10
Brings the total price at your door step of $1398.
Sorry I was $100 off.. :bahaha:
I am aware of ECU's not attracting the stamp duty, please re-read my above post that I quoted from the email I received from Greenline Yesterday.
i called ap engineering (apexi and ap engineering although under the same company, operate as separate entities) in japan about 2-3 weeks ago about an ap engineering pfc for the hcr32. they said if i were to order and pay for one back then, i should expect one by mid october. aparently even in japan they arent that easy to get. what is the difference betweent he apexi standard unit and the ap engineering unit? well, their response to that one was "because we make one and apexi dont!" there is no real difference at all except the hike in price, unless you have the upgrades to make it the pro version.
The pro version isn't all that much more.
It offers an ignition cut instead of the conventional fuel cut that will only be of benifit if you are running for example NOS, and launch control.
Hold the accelerator flat while the clutch is in, meanwhile pressing a button will hold the rev's at a specified RPM.
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
