I've checked my timing belt today. And crank dots match up(dot on the timing belt cover and the first dot from the left( the orange one), intake cam dots match up. But exhaust one is slightly offset. Like 1/2 tooth or 1tooth. Its hard to read, the angle ain't good. I've checked the timing with a timing light. And it was spot on 15degrees(rb20det) at idle. So CAS was positioned correctly. I tried setting it at 20 and 25 degrees. Car feels way better and feels like it felt the first day I installed the rb20det. 1.5 years ago.
I did change timing belt and all the pulleys prior to install.
Can it be my timing belt was too tight and it stretched ? I can push it in with my finger, around 1cm or less.
So what could be wrong? How to fix this ?
Thanks!
https://www.sau.com.au/forums/topic/230196-timing-belt-question/
If your exhaust looks offset from the front, you need to line up the camgear from the back. As in follow the dotted tooth along its side and line it up from the back of the gear with the rear timing plate. Then you can line it up spot on, from the front because of the lean of the motor and whatnot its difficult to get it bang on.
I mark the inlet and exhaust gears along the side of the respective teeth and line it up that way, it helps get it right everytime. Your exhaust could be one tooth out, which i think equals 15 degrees of cam timing. It would explain why you've had to advance the base timing inorder to get it running better.
when you put a new belt on you want all the slack on the same side as the tensioner not the idler pulley. ensure the belt between the crank and the cam pulley on the idler side is tight as you can get it by hand...... that way when you crank up the tensioner the pulleys dont move
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
