hey dude, i was going to do it with a big stainless steal one, while ur at it u should put the pod in the front bar and then uve got proper cold air, u shouldnt loose ne power as long as u stick with the same or slightly larger diameter piping.
A guy I know in SDU has had this done, he hasn't lost any power, if anything I think he has gained a few kw, and he has a bit more induction noise.
His car is basicaly stock, just with a pod and no cold air intake, he is running mid to high 15's for the 1/4.
if your get the intake pipe to be the same diameter as the stock one, there shouldnt really be any ramifications at all.
I didnt know what the thing off teh side of teh intake was either :-?
gaining or losing power would be from the result of changing the size of the diameter of the pipe.
If the pipes are cheap and easy t make, maybe consider making 2 or 3 in different sizes and determine if you can feel any difference's.
i thought the black box off to the side of intake was a resonator box
to quieten down the intake noise there is no hose off the engine for this to be a oil catch can , the hose off the back goes to your intake manifold collector.
you could replace it WITH A ALUMINIUM OR STAINLESS one but your induction noise would be louder ,actually sounds quit good the one i heard
eryc
no down side i liked it sounded good
he used a one piece aluminium one for a comadore and cut it into 4 parts and joined it back together(so all the bends suited the skyline) with silicon joiners so it would fit into his cold air box he made with pod filter
i think the pipe and filter cost $190.00 at auto shop (not the best pod filter ive seen just a cheapie) but he had a good filter already
he had to get a pipe welded on it for the hose wich goes to the intake manifold collector cost $15.00 3x silicone conectors about $10 or $15 dollars each
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
    • Being a manual, we very quickly ordered new R34 gearbox (From Nissan) and remaining parts from Kudos motorsports. Would highly recommend the team there. Ultra helpful and quick to share advice and upgrades. We are in the middle of taking the Auto out (Genuine 94,000/kms) and putting the Manual in this weekend. Part 2 of the build will include likely a Plazaman Intercooler and Plenium, Hks Exhaust with Tomei Dump (ordered).
