Make:nissan skyline
Model:r33 series 2
Milage:average 65 thou
Transmission:manual
Colour:black
Complied?yes
RWC supplied?no
Currently registered?no
Price:$10,000 ono
Contact:0420947201
Comments / Modifications:lots
Images:
hey guys
i have to now sell my beast
r33 series 2
its dammaged
was in an accident doing 20 ks
front ender
new front is there ready to go on
needs bonnet
drivers side headlight and windscreen
alot of money has gone into this car
will be sad to let it go
r34 brakes all round
brand new hybrid front mount with proper polished piping
race brass button clutch
short shifter
biig alarm with full keyless entry and immobilise
turbo timer not hooked up yet
spitfire performance box filter
turbosmart type 3 supersonic bov
boost controller
new turbo
rare sunroof
full stainless stell exhaust system with nismo dump pipe
never boosted over 9 pound
lots of goodies on this car
custom dash
$1500 adjustable suspension
near new
will 2 need new tyres an 1 rim is buckled
has full custom bodykit
lots more
very fast car
left alot for dead
pm me or call for details
willing to swap for another car
eg another skyline or gtir 200sx anything
URGENT SALE
pm me for pics or contact me on 0420947201
price is very negotiable
any reasonable offer accepted
Drifty
pics for serious people
Edited by harley
https://www.sau.com.au/forums/topic/230230-cheap-r33-series-2/
front bar, bonnet and windscreen damaged from a 20km/h accident?
"new turbo". What type? Specs? Why no rego? What is "average 65 thou" supposed to mean for odo reading? How was the rim buckled and was the suspension or anything else damaged in the process? Adjustable suspension? What type and adjustable in what way?
"left alot for dead" - in other words has had it's gutts thrashed out?
More info
Edited by Jago
  • 1 month later...
yes car skipped off to the left as it was going around a right hand corner and went down a ditch up a ditch and into a tree.
and yes it was average 20kms .
Has a near new standard turbo as the old 1 blew. less then 3 months use
The car is unregistered because it has sat there since the accident as i was fixing it but have now come into financial difficulty
i say average 65 thou as the car is down in sydney atm and it has about 65 or 75 thousand k's on it cant remember which 1 sorry
rim was buckled from a previous minor gutter hit from where the car aquaplaned in the wet.
suspension is adjustable as in damper and thatcant remember exact brand off hand but they are a decent brand and are less then 3 months old.
and saying left alot for dead meant is was a very quick car
not a thrashed piece of shit
just needs new water pump putting in but new 1 is there
any1 interested?
prefer swap
    • Ok awesome! I’m not running a aac/iacv (although I do have the r34 iacv but I’m running the heater core loop. I’m running the chase bays booster delete so In that case would I need to block off those posts? So at the moment I need to run from one of the posts to the fpr and then a separate post to the boost controller then to the wastegate? Also I’m assuming that each port has a specific use like the first one farthest to the left would be (for example) manifold to fpr and then second would be to boost controller?
    • I was just going through this on Neil's car (33 gtst). Assuming you are using standard AAC and Cold start valves, you need Post Turbo Pre throttle to Boost Controller (if you have one) then to Turbo Wastegate Pre throttle to AAC input AAC input T piece to Cold start input Cold start output to plenum post throttle AAC Output to plenum post throttle AAC Output to brake booster (needs a 1 way valve) Plenum post throttle to Fuel Pressure Regulator Plenum post throttle to Blow off valve signal Plenum post throttle to Boost controller input (if you have one)
    • I’m trying to figure out the purpose of these fittings. Assuming they’re for coolant but not sure where the lead to. I know the bigger one on the right (which isn’t filled) is the brake booster. If anyone has a photo of a diagram of this intake or has a set of instructions it’d be greatly appreciated
    • How much is that r32? Is that $170k or $1.7m
    • Ahhh! My silly brain was thinking Nissan started selling them straight away, but they waited w or three years didn't they?   Maybe Duncan should build an R35 race car over the V37... There's a cheap yellow one on car sales Duncan, would only need your splash of purple added...
