Item: Conpaq V6000 Laptop
Age: 6 months
Condition: Very good
Price: $550
Contact: PM
Comments: All up ive spent in excess of 1400 on this, so i will not lower the price. PRICE IS FIRM!
looking at buying a proper workstation so i can work from home. dont really need a laptop.
Purchased this 6 months ago..
Specs:
AMD Turion 64 x 2 1.7ghz Processor
1 Gig of Ram
80 Gig Hard drive
Built in Microphone
Wifi
Nvidia 128mb Integrated Graphics, Shared with Memory
5 in 1 digital card reader
Windows Vista Home (on separate partition for easy install)
You Get:
The computer (duh)
power cord
1 x "Life" Messenger style laptop bag
1 x Targus Extreme Back Pack laptop bag
1 x Logitech G5 gaming mouse
Computer will come with a Fresh new copy of Vista install, The full Adobe CS3 Software suite, and Microsoft Office Student 2007.
Pick up from Kilsyth in Victoria
Pics:
http://i145.photobucket.com/albums/r228/sp...17/P9200217.jpg
targus laptop bag:
http://www.electronicsoutfitter.com/images...18-tsb032us.jpg
https://www.sau.com.au/forums/topic/230239-compaq-laptop-with-extras/
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
