Gtr O2 Sensors / Rb25det + Z32
Madaz
 Share
  • Replies 66
Posted Images
yeah thats the titania R32 GTR one maybe R34 use titania also i dont know maybe you can pm me your VIN and i can ring nissan or you can ring nissan with your vin and get a part number
Hi there, I need 2 each (I think) for R33 based Stagea 260RS. Just to muddy the waters (maybe) I have copied this little lot, old prices from around 2005, from the o2 sensor sticky;
OXYGEN SENSOR replace @ 40000kms (ref sydneykid)
NGK/ NTK Part number OZA395-E2 O2 Sensor Nissan Pulsar N14/N1
Genuine article no need to change plug or anything.
NGK OZA395-E2 (This comes now as BOSCH part number 2269013007) $129 from REPCO
Genuine Nissan
Part number - 22690-83T12
$169.00 each
What is the expected delivery date considering your closing date/order quantities are met? Does the price include GST?
Cheers GW
Hmmm interesting mate. That is a Zirconia sensor, so maybe I am in luck. As I posted in the other topic, I managed to get some part numbers off the sensor. It is a Bosch with A24-A21 141 xxxxxx. I couldn't work out the xxxx part, but I did a Google search which showed someone selling one second hand with the part number A24-A21 141 63072. I also found another forum where they said it was Zirconia, so who knows? I'll see what I can find out tomorrow.
Genuine Nissan
$169.00 each
Cheers GW
well i imagine then if OZA395-E2 is for the RS260 then that will also suit the R33 GTR since you share the same engine who ever though O2 sensors could be so hard
Hi there,the info part #'s I posted related to RB25DET I suspect as SK has auto Stagea. At the end of the day it is all gunna relate to your ecu & what model Skylines/Stags use similar ecu's. The discussion regarding Titania(ium?) oxide vs Zirconia oxide I imagine relates to different response curves of the two primary elements when exposed to oxygen, which means the compatible ecu's will have different input measuring ccts. Maybe we take a punt & say R33GTR o2 sensor will suit 260RS & R33GTST will suit the RB25DET equiped beasts? R32/R34 series cars............dunno. Just found this...........Check out the attachment. Narrow & fast (Titania) vs wide & slow (zirconia)?
Anyway I am happy to buy 2 x (NGK/ NTK Part number OZA395-E2 O2 Sensor Nissan Pulsar N14/N1
Genuine article no need to change plug or anything.) for my application, I will sell the buggers on ebay or something if they are the wrong jobbies & try again.
Cheers GW
All_About_Lambda_Sensors.doc
im trying to get O2 sensor's sorted for all models R32 RB20 but no one has asked for them so havnt had to look for any info R32 GTR to which i thought would suit all RB26 models so this is all new to me when i started the group buy based on the NGK website only having 2 part numbers 1 for R32 RB26dett and 1 for R33 RB25det i may the ASSumption there was only do 2 sorts for the 3 variety of engine model cars, if that makes sense
Sorry mate im confused, I need 2 x R33 GTR O2 sensors.. can you get those in?
yeah cheers for all your info and help, i was confident the 260RS had the S3 RB26dett out of the R33 but its all about dump pipe's thread type also,
i didnt get a chance to ring my contact today as i was trying to sort out braided lines that didn't fit my brakes... any ways will give it a shot tomorrow
Cheers GW
The 260RS has the same sized thread as the R33 GTR. It is the larger 18mm thread. The R32 GTR is the smaller 12mm thread. I assumed that since the R32 GTR uses Titania sensors, then the R33 must also use Titania. I have been searching and going off what other forums have said, as well as the fact that the wires on the stock 260RS sensors are white/white/black it looks like the R33 GTR may actually be Zirconia. Prior to this group-buy I had already purchased some OZA395 sensors which I thought were wrong. I am going to try them this week (once the socket arrives) and I will confirm back to the forum if they work or not. Hopefully that will stop the confusion.
Simon
ok i rang for a price on the OZA395-E2
5x OZA395-E2 = $68.15inc
i also found out some new information that people may not of been aware of
Zirconia are made by Bosch
Titania are made by Siemens
now when the R32 GTR was built Nissan might of had a deal with Siemens for them to supply all there O2 sensors and when it came to the R33 they MAY have changed to BOSCH contract which would make sense as RB25 have zirconia why wouldn't RB26
the aforementioned statement are purely thoughts of my own and are not based upon anything ive read
my source tells me there is an easy check to see if your running Titania or Zirconia
unplug you O2 sensor and start your car measure the signal wire with multimeter and...
Zirconia should give a reading .3-.4 volts
Titania should give a reading of 3-5volts
Last night I put my sensors into my Stagea 260RS. I can confirm that the sensors are OZA395-E2 and they work prefectly. Apparently the 260RS is identical to the R33 GTR. I'd appreciate if someone can confirm. I'm pretty sure they are.
Please see my notes in this thread:
http://www.skylinesaustralia.com/forums/O2...iew=getlastpost
 Share
    • i have 2 MTX thunder amps they do have the line input aswell but i have no idea where the connectors are to use. so for ease of being able to run 2 sets of RCA leads im just using the convertor.
    • The existing factory sub feed should already have a sum of L+R and a low pass filter, so it probably isn't necessary to take another L and R feed from the HU.  If it didn't have a factory sub output, then that would be the best option though. Does your new amp not have speaker level inputs?  that would eliminate the need for the speaker - line level converter completely.
    • The query here, is how do you arrange all of your spares and other random items? And then, what do you do, if you think you're hitting that point where you won't need them any more?   So, but of background; I've had lots of different cars, and tinkered with lots of cars over the last 18 odd years. In addition, I have a habit of ending up with things, I'll now never need again. For example, for the R33, I've got a side mount intercooler, and a GTR front mount cooler, as well as random items like aftermarket cam gears, starter motors, power steering pumps, and even things as random as the really small fuse box, that sits right beside the battery.  So firstly, I've got a lot of stuff right there, that I'll never need again, as I'm not playing street/stock cars. So, I probably need to clear some items out, and at the same time, I hate Facebook Market place and dealing with people. So other than throwing this stuff out, how do you guys deal with it? Do you have a similar stash of parts hidden away taking up space?   So then the next part is, I have lots of stuff like aluminium pipe to make inlets from, lots and lots of electrical stuff too for making custom wiring looms, and so many random things. How do you guys organise all of your stuff? I've moved a lot, and lots of my stuff was just in random cardboard and plastic boxes, that were starting to fall apart! Lots of it was stacked on shelves in said boxes, and I've just gotten new shelving, and I'm re arranging the garage to fit some new (to me) large tools in. That means I'm presently opening boxes, being ruthless and ditching the trash (I think about 30 cables that would suit a TV/Desktop PC went in the bin alone!). However, now I've got parts laying in the middle of the garage floor while I work out how to store them on shelves. The shelves are all high, so if I lay all the parts out nicely on shelving, I lose heaps of space. But if I shove them all back in boxes, I'm back to square one!   So what mysterious and creative storage solutions have you come up with? That is other than making the garage bigger, and buying more shelving, and pushing this problem back another 5 to 10 years...   Oh, and lots of things I have, are for projects I want to do one day, or am slowly doing too... The 80HDs can make life hard sometimes... So more storage space probably isn't the best idea...   Let's add another random question too, how much space is being taken up in your workshop/garage from parts you bought years ago, and still haven't fitted? Example, I have a brand new Safari Snorkel for the LandCruiser, and a box of RedArc gauges.    Since November of 2016...
    • So I've been working on the car a fair bit, doing a lot of little things. Preparing some projects for this winter, as I'm taking 13 weeks off very soon for parental leave. Have my second kid on the way and he's due any week now. I'll need something to do while he's sleeping. I also usually take the car off the road in about a month and a half, until sometime around the end of March.  Still making slight adjustments to my tune, as the cold weather settles in. I've also had to start dropping boost and tire pressure as the weather gets cooler. It's getting very swirly at highway speeds. I drop to 20psi at 20C and 18psi spring pressure at 10C IAT's. I'm currently on 255 Falcon RT660's, but may look into running 275's next summer. They will fit, but barely. Might have to raise the rear a tad.  I'll start redoing my exhaust Monday, as I have the week off. I currently have an oval center muffler and cannon rear muffler. I've been told more then once from people behind me that my rear bumper is going to catch on fire one day. Seems I blow 5-10 second flames after doing a pull. No clue if that's the WMI, as I've never been able to do that before with other cars. I wanted to angle my tip down a tad so flames are pointed down and away from bumper. I also wanted to take the opportunity to reconfigure my exhaust line. I'm going to move my oval muffler to the rear with a pie cut angled tip and put in a new smaller round muffler in the center. I've rocked cannon mufflers on this car for the last few years and want to transition back the oval muffler look. I've also been looking for a stainless project to try out the new solar flux I bought. I'll post pictures on Monday, should be able to wrap that up in a day.  I'm also picking up another rear subframe this week. I wanted a second so that I could modify one with a gk tech anti squat reduction kit during the winter, and still be able to keep the car a roller so I can back it out of the garage if needed. I will also be caging it this winter. More on that later. Lastly, Speedtek still hasn't given me diddly squat. Every week for the last 4 weeks, they have been saying next week. They told me Friday to expect a shipping label that day to ship my two bad sets of ring and pinions back and nothing. There's definitely been more contact since I started destroying their company any chance I get on Facebook, but it's still just words without action.
    • Have you done a pressure test on your intake/piping? Cleaned your IACV and Cold start valve?
