Hey
My R33 GTR came with a custom catch can/water tank that looks identical to the one pictured above, does anyone know what brand catch can/water tank it is? Looks to be a nice neat design but there's no where to open the can up to drain the oil or clean the inside nor any markings to identify
Anyways, its not currently connected and I was just wondering what the best way to plumb it up is, where does the 2nd yellow hose connect to under the intake manifold?
Car isn't anything crazy, just run 14psi, with exhaust, PFC etc etc
Thanks
https://www.sau.com.au/forums/topic/230249-r33-gtr-catch-can/
You could find, that hose isn't connected to anything, but just vents behind the gear box.
Yeah mine was like that, which is bad, so I took it all out.
But in that pic, it is connected to something, I just gotta find a better pic at home.
looks similar to arc style
+1
I'm pretty sure ARC doesn't make these anymore but I could be wrong.
Also I'm hunting for one of these.
Cheers
Grant
Edited by Count Grantleyish
really depends if you want to keep it legal..
I have mine set-up such that both cam breathers run to a large baffled tank with the baffle there to force the blowby into the tank rather than going straight to the oulet (this depends on the shape of the tank). I then pipe the blowby from the can to the rear of the car. The legal version of this set-up would see the breather from the catch can running to the inlet pipe on the turbo/s. There are plenty of other ways of dealing with pcv but for a streetcar this seems to be the easiest.
edit; I definantly would recommend a catch can, take a look at the inside of a stock gtr intercooler to see why!
Edited by DCIEVE
there are plenty of companies that make combination washer bottle/catch cans for R33 and 34 GTR. no way to tell where yours is from without pics. to empty it you simlpy unhook the pipes, un bolt it, lift it out and tip it upside down.
when i get close to back on the road,
i have a massive sheet of alloy at my friends workshop.
we're making airbox and an oil catch/radiator overflow/washer bottle all in one to go in the location where the 32 Gtr battery usually is.
Edited by Angus Smart
Thanks for all the help guys, much appreciated
My car is going for a tune on Friday so I might see if the mechanic can hook it up for me while I'm there if not then I will just do it over the weekend
Appreciate the offer Gareth, I should be a member by the next official event and will more than likely turn up. If its not connected by then your help would be much appreciated
Thanks
Sure, if you get stuck PM me, once I get the oil change done I usually take the car out most weekends.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
