yep, it's the same car.
kranker, the boys will confirm but I believe it was running sunoco fuel. which it turns out may not have been a benefit as it tends to go off once the drum is cracked open. you can visibly see, smell and feel the stuff is different after a while sitting.
There isn't a fuel that Sunoco make that is as poor as PULP. Don't kid yourself, dude.
  • Replies 66
d'oh. I must be blind. I'm trying to find the post where I said sunoco makes fuel that is worse than pulp? maybe I wrote that in invisible ink. read again what I posted. have you never heard of fuel going off? we have had this problem for years. and it makes for a tough choice. do you pay through the nose for a 20L drum and use it fresh. or save money, buy the 60L drum, but if you meetings are a few months apart you often find the last 20L you use is no good, to the point of the car not even running properly. it's not just sunoco fuel, we've had that problem with other race fuels too. as I said, once it goes off you can see, smell and feel the difference. so if you deny that you are the one kidding yourself...
Even Sunoco race gas that has 'gone off' will be a benefit ahead of PULP. It's at the top of this page if you wanna check back. Maybe the tune-up doesn't suit it once it's gone off but it's still a better fuel than PULP in all circumstances. Also, I would've thought this car goes through easily enough fuel to justify 205's of the stuff?!? If it's stored properly (tightly sealed containers in a dark, temperature controlled environment) there aren't any problems with contamination or 'going off'.
lol, fk me dead "Mr Sunoco". I'm not saying Russ's car was having any problems on the night with fuel, or flux capacitor or anything else. it certainly wouldn't have run as well as it did. You seem to be very defensive about that. so I'm sorry, reading my post I can understand why you may think I was making some excuse (though for what and why I have no idea?!) but I can see why you might think that. so I will state again, that's not the case, i'm sure on the night the car was sweet as a nut, the air was clean and pure and the fuel was fresh and tasty.
but telling me that fuel that has gone off is still better than pulp is just plain nonsense. doesn't matter what brand, sunoco, elf, vp, whatever. once it's gone mate it's only good for doing small arson jobs with. and yes of course if it's tightly sealed and stored correctly it will last a fair while. but sometimes people make mistakes, sometime the drums fuel comes in do not seal well once you've cracked open the factory seal. fuel gets carted around from meeting to meeting etc. I have personally had this problem. we have had it go off so bad the car would barely run at all. and in a pinch we had to just drain the tank and use some servo grade pulp and what do you know? the car ran much better, and even better again with fresh race fuel. wow, I didn't think I'd have to go to such effort to explain such a simple to understand comment.
anyway, if you still believe old gone off race fuel is better than pulp I may have some fuel for sale after I check the garage that you may be interested in! :D
Don't hurt yourself, Richard. :D Jeez. I'm hardly Mr Sunoco. I don't even use the stuff in my car. Maybe I read this wrong;
So either the race fuel was of benefit over PULP or it had gone off and the car ran like shit?!? Surely they wouldn't run race fuel without tuning for it? That'd just be dumb.
:D
Oh and as for tasty fuel, Sunoco's just wrong, mate!!! Everyone with any taste knows that C16 is where the flava's at!
lol, I admit the statement doesn't make much sense reading it back. :D they have had problems with the car not performing well on old fuel, but I don't think they had that problem that night. :D hope that clears up what I meant. sometimes I type like I am almost illiterate. brain faster than hands.
but I stand buy the fact that the old fuel isn't even fun to sniff.
for personal flavour I like avgas, it's cheap, they sell it at the track and cams give you a little book so you can buy some. I guess it's like VB vs asahi!
*note do not sniff race fuel, high in carcinogens...
  • 7 months later...
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
