I'm pretty sure the stock plug for RB26 is heat range 7. I know GTSts are heat range 6, but fairly sure the GTRs run 7s stock.
anyway, either some 7s or 8s would be the go, depending on boost level and ignition system. for gap you will find it hard to run 1.1mm if you are running decent boost. you'll probably wind up around .9mm or .8mm.
Ive always used NGK IRIWAY 7 plugs in my modified engines. My tuner wont tune with anything else. Not sure why.
They'd want to be good for $120! (not each).
Having said that, ive never had a problem with my stock ignition.
Iridiums are for people who light cigars with $100 notes. A waste of good money even on very high powered cars a set of correctly matched and gapped copper plugs are no problem, so why the hell are you still buying them guys?
NGK coppers. Inexpensive, reliable and work a treat. :down:
Edited by rev210
NGK coppers. Inexpensive, reliable and work a treat. :P
Here here
