hi guys
I have a alarm system and the remote doesn't seem to operate as it should.
thought randomly it works fine.
I assumed it was the battery, but when I replaced it it was still the same.
anyone have a rough idea of what may be the issue or is it simply the fact my remote is stuffed?
If there is anymore information I need to share to assist with someone helping me.
please let me know.
Regards
Sloane
https://www.sau.com.au/forums/topic/230330-alarm-remote-not-operating/
I have the smae problem wuth my remote.
I used to try changing the battery, I now just crack the shits and tap the remote on something...... lol not the best fix, but it makes me feel better :)
If any one knows a way to fix this issue,I would also be greatful for the information.
yeah mate had the exact problem with a customers car at work. pulled it apart and found two dry solder joints. resolder them and it worked like a treat. if you are good with a solder iron then give it a go cos if you take else where they will tell you to replace the remote.
Same god damn problem with me aswell!
Curse the previous owner who had to install a shitty eBay alarm grrr !!
Solder it aye? Hmm.
And what if that doesnt work lol ?
I played around with the 2 dials in the remote..
Didnt do anything for me.
MRXTCZ
Solder it aye? Hmm.
Don't touch it unless you have a back up plan if you stuff it up lol
I notice its been working fine when I point remote to engine direction :ermm:
I remember I've got a Spare Remote but its at a relatives so will have to pick it up.
I lurk on a huge list of forums, lol.
And your dead right, dont try to fix the remote if you dont have a fail-safe plan, that's just asking for trouble, and will put you into a bad situation.
With my previous car, someone installed a cheap ebay POS alarm, and wired it in quite stupidly, so I had the car towed (became unstartable) to an auto electrician and set him to task to remove the mess and set the car back to stock.
He did this, and then I went and got a proper alarm system installed in the car.
B.
  • 3 weeks later...
hey guys
stupid remote not working again
i tried my spare remote to see if it worked and didn't do anything either....
now I'm getting all sorts of weird beeping and basically have no friggin central locking meaning i need to open door via the key.....
and to start my car now I have to put key in ignition
set the alarm off then press remote to disable immobiliser and alarm (only time it seems to work)
just to start my car!!!! :sleep:
I'm going to ring the installers tomorrow who installed the alarm about the issues I'm having.
I got this installed on 25th January 2008
spent about $2200 at their workshop
Just curious as to whether they should fix this issue under a warranty?
Can some please verify that.
If all goes down the drain I will be seeing Chris Rogers.
