Complete R33 Series 1.5 Passenger door including door trim, window & reg & mirror $250
R33 LSD diff centre inc ABS sensor $ 250
R33 tail lights. 2 sets, blue & silver. $100pair
R33 ABS Module $50
R32 GTR power steer pump $100
R32 GTST bonnett, burgundy. no dints. $150
R32 rear seat $50
R32 GTST Steering wheel $30
MT street radials 235/60R15 on 15" steel rims. Done 3 passes. $400
MT street radials 235/60R15 on 15" steel rims. Done a dozen passes $300
other bits and pieces, just PM
Item:
Condition:good, second hand.
Price:negotiable
To Fit: (What car) R32 & r33 GTST
Contact:Stuart
Comments:pick-up or post
https://www.sau.com.au/forums/topic/230338-r32-r33-gtst-parts/
Have all components on the top of the column including clock spring and blinker switch assy.
Also found other parts:
Climate control module for R32 & R33 $80ea
Front and rear wiper motors R33 $30ea
Rear wiper motor R32 $30
second ABS module R33
D/S electric mirror R33 $50
RB26 exhaust manifold Plates (new) $90
Do you have a clock spring, if so do you have pictures?
Thanks
I'll PM you
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
