Item:
i have a brand new PPG built gearbox to suit gtr skyline i just got it built to suit my car and will handle up to 800hp at the wheels no problem, its helicel billet gearset 1st, 2nd,3rd, 4th.std 5th, its also snchromesh, all new bearings and gaskets. sold as box only, no transfer case.
i wanted it for the street, its brand new hardly used just fitted to see if its all good which it is. lucky to have 50kms on it. reason of selling is as im going to start draging the car and going holinger seq. this box cost me over $7500 new built.
Item Condition: brand new
Price and Payment Conditions: $5500 ono
Pictures:
Contact Details: pm me
https://www.sau.com.au/forums/topic/230339-ppg-gearbox-to-suit-gtr-skyline/
  • 5 weeks later...
Gday mate, is this still avaialble and can you tell me if you got the upgraded shaft with this as PPG also do a much beefier shaft to their standard issue.
Which dealer did you buy this from? I've been quoted $5200 for brand new so $7500 is quite pricey.
  • 1 month later...
$5200? where is this from? as im lookin for a box myself
Me as well, who sells them that cheap?
I´m looking for a PPG upgrade for my R34...
  • 10 months later...
i used the box at jambo and it was great even with the sticky track. i have driven it a few times on the street as some sunday mountain driving and taking it once to powercruise. im going full dog box now for drag use only. this box is great if i was going to drive it every week on the street but im starting to use my car more for track now as i have other day cars to drive.
the box is still currently in the car till next monday/tuesday if u are local and went to see it running in the car. otherwise its coming out next week regardless as my new box has come. PM if anyones interested.
Mate where is my catch can?! Its been like 4 months since I paid for it with nothing but lies since the day the funds cleared!
You need to refund my money!
PM sent!
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
