hey people has anyone got tein lowered springs in there car as im think of getting some, just wanted to know if its worth spending the extra money on the teins rather than king spring.. and before people start saying get coil overs i have had them before and loved so much but have been through to many head f**ks with them getting defected.
so if anyone can tell me what the tein lowered spring are like would be great!
https://www.sau.com.au/forums/topic/230403-tein-lowered-springs/
  • 3 weeks later...
The suprising thing that I found was the ride height is just right. Not too low to attract attention or as high as stock. Ride is not hard either. If you want I can take a picture of the ride height. Also note to be careful of ebay imitations. There are a lot of copys going around. I am no expert on the matter, but the guy who sold me the springs ( auto shop) said the good quality springs are cold rolled ?
i must agree with everyone else i had a set of tein lowered springs in my old r34 and they were great.... lowered it and the ride height was perfect not too low not too high and cops didnt even look twice
Im installing some in my R33 this weekend (wanted coilovers but i got them brand new for a set of batty wheels) so untill i can afford coilovers, they will suffice.
Will let you know how thy go, with before/after pics.
i too have tein super streets in my r33
ride quality is awesome. sits well on the road doesnt bounce around not too harsh on big bumps. feels good through corners too. best value for money coil overs i believe.
I think hes talking about just the Tein springs on OEM shocks, not the complete coil over setup.
But goot to hear more positive comments on the Tein coilovers, as thats what im planning on getting one day.
i also have Tein super street coilovers in my car
made everything feel so much nicer
launching, corners, driving in general
im very pleased with mine
plus they have valve adjustments so you can make them soft or hard when ever you want
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
