how's the car running now ? .. is the throttle getting any better ? ... im no mechanic but from previouse complaints it sounds like miss fire .... my mates gti-r would backfire and not rev any higher then 4500rpm
he had some cash lying around put a wolf v500 and it told him exhaust leak, some how a hole in the dump pipe was mucking the sensors up and throwing things out.. 11k later its runs like a jet :P sorrry a bit of subject ..... check your spark plugs hehe
https://www.sau.com.au/forums/topic/230424-woooooo/page/2/#findComment-4064463
finally registered in my name :)
Just filled it up with premium. $98 :P will be interesting to see how many k's I get
Looking forward to throwing in the JVC DVD player tomorrow arvo though
Oh and the engine runs smoothe as.. Must have been water in somewhere.
Edited by Silhouette31
https://www.sau.com.au/forums/topic/230424-woooooo/page/2/#findComment-4086279
finally registered in my name :rolleyes:
Just filled it up with premium. $98 :) will be interesting to see how many k's I get
i had something similar ages ago i washed my K&N panal filter and re-oiled it but not all the water had drained out. made it cough and splutter till it was properly dry (stoopid me)
https://www.sau.com.au/forums/topic/230424-woooooo/page/2/#findComment-4087221
aaargh!!
my passenger side fog light was blown, so I took the housing off to change globes..
didn't look at how the clip that holds the globe in works and just took the little screw off for the earth tab.. When I put it back together (and worked out how the clip worked), the head tore off the screw... Now I have nothing to hold the globe in and no earth tab... So my entire fog/indicator light housing is useless cause of one stupid screw!
I've put up a WTB if anyone has one.
http://www.skylinesaustralia.com/forums/Wt...or-t233204.html
https://www.sau.com.au/forums/topic/230424-woooooo/page/2/#findComment-4088422
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
