Ok well as you remember before fuel was leaning out very dangerously.
Ive fixed the problem by fitting new pump and regulator.
Took it to the dyno today to see if it still had the cut...
and it did :P but thanks to better fueling ive actually gained power and A/F ratios are much safer. (see pic)
All i need to do now is either get my ECU tuned or fit a boost cut defender and/or tune the SAFCII.
After talking to the guys at Envy after my run they were talking about fitting a 300zx (Z32 i think) airflow meter and that should fix my problem.
Has anyone done this? does it work without having to fiddle the standard 32 ECU??
Dyno results with new pump and reg. - note: it still cuts out
https://www.sau.com.au/forums/topic/23045-hks2530-stage-2/
  • Replies 80
yeah good call. i dont want to buy one then find out i cant use the two together.
is it possible to retain my ecu settings and get someone just to remove the max setting? or for that price would it be more economical to just get the whole thing remapped on the dyno?
https://www.sau.com.au/forums/topic/23045-hks2530-stage-2/#findComment-493801
bbenny,
A boost cut defender, whilst not an ideal way of doing business, will do the job fine.
If you are on a limited budget, this is perfect. Upside is that you can pick them up second hand, and if you decide to go remapped ecu, or something like e-manage down the track, you could easily sell it again and recoup some if not most of the money you paid;)
If you need to find one second hand, drop me a pm and I can point you in the right direction, as I know of a shop here in Adelaide that has a couple in good condition.
https://www.sau.com.au/forums/topic/23045-hks2530-stage-2/#findComment-493889
Oh and a boost cut defender will definately be alot cheaper than a remapped ecu and z32 afm. The downside is that you may have to tune to 1.2bar or whatever, then if you wind the boost down it will run a bit rich as the ecu/safc wont know the difference between the air flows - if you know what I mean.
https://www.sau.com.au/forums/topic/23045-hks2530-stage-2/#findComment-493891
Brody: its running about 10 - 12psi there it creeps a little so i didnt get to see exactly how high, but its fairly low.
i plan on running 1.2bar (18psi)
Steve: i think i am going to have to run a boost cut defender as this whole project has made me poor. my only concern is that it may affect how the SAFC functions...
https://www.sau.com.au/forums/topic/23045-hks2530-stage-2/#findComment-493916
:D :D :D :D
213rwKW!
anyone wanna swap an r34 turbo for 2530 :)
hey your starting to leant out again at 5300, i think your injectors
are running out capacity now, so you will have to increase fuel pressure on the regulator but then you will run richer at bottom end...........
------> remap will fix all your problems! :P
https://www.sau.com.au/forums/topic/23045-hks2530-stage-2/#findComment-494406
bbenny... I have a std ECU that doesnt appears to have a boost cut of fuel cut, but still has the speed limiter.
I am no longer using it, so your welcom to try it to see if it solve your problem.
I say it doesnt have the std cuts because i accidentally ran the std turbo up to 21 psi with no cuts. Then more recently i was running a TD06 at 1.2bar with no cuts.
...may be worth a try ... let me know.
https://www.sau.com.au/forums/topic/23045-hks2530-stage-2/#findComment-494438
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
