Don't think this is as good as it should be...heard most ppl getting bout 450-500km outta full tank with no harsh thrashing....best ive got was about 410....keeping revs under 3500 though....
before i start changing sparks/coils fuel filter, waz wondering if theres any truth to that injector cleaner crap i can just throw in next time i fill up....wat brand if any good?
thanks aye!
thanks aye!
Try Nulon Injector cleaner. Are you running 98 Premium and what pressure are you running in your tires?
Mileage is also dependent on driving environment. eg. City Vs Highway.
Might as well clean your air filter and plugs while you are at it mate.
Cheers.
Sam.
yep...alwayz run 98....mostly suburb driving...no thrashing....gonna try that nulon stuff then...thanks aye....
just wanted to make sure i wasnt throwing crap in the tank......thanks again....
anyone ever gotten better results through this injector cleaner stuff?
Put the injector cleaner in when you have about a quater of fuel left. Fill the tank up and run it though.
Then change your fuel filter and spark plugs.
Check your tyre pressure, (depends on your tyres) I pump mine 34 Psi all round, or 36 Psi at the front and 34 Psi at the rear.
I think N/A Skylines have an O2 (Oxygen) Sensor..? If so get your mechanic to check it out.
I know turbo cars have it and its job is pretty much to make sure the car is not running too lean or too rich.
