Have left over empty front cut r32 gtst complete straight front half rails radiator support all good nic.
r32 radiator support $100ono includes strut towers and front half of rails
r32 potenza front struts pair (look very clean and not old) $40
r32 rack and 4ws pump $60
r32 ac pump and condensor $50
r32 loom complete
r32 brake master cylinder and booster
r32 boss kit
Other bits available eg vents dash pad pm i may have it . no panels or lights
s15 Tanabe front strut brace $80
R33 front hubs and uprights $40pair
Added
R32 steering rack very good condition $80
R32 sway bar $30
R32 air box $50
s13 power steer pump $30
S13 sr air box $50
  • 4 weeks later...
    • Because the drive dog for the steeering angle sensor is present on wheels that came in HICAS cars and not present on wheels that came on non-HICAS cars. Not that I would let that bother me, because HICAS is trash and any excuse to get rid of it is a good excuse.
    • My plan is to replace both Shift Solenoids A and B, and good idea on the Torque Convertor Solenoid as well.
    • I mean, I am always taking donations for a newer model!!  If you'd like to sponsor me. I would gladly get something else!! LOL
    • Interesting.  Great info. thank you.  Give a few days to get that name plate.  I have a busy life most weeks.  I will be in touch.
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
