focal splits, high end alpine deck, and soundstream sub should get you what you want to achieve... i listen to alot of everything and i mean everything... the alpine deck allows for alot of options reguarding sound quality for different types of music. e.g. parametric E.Q
yeh i got a 12" alpine sub, pioneer deck, mbquarts splits up front and want to go turantula 6x9 at the back.
even thinking of changing the front splits to turantula ones too..
how do 6" fit into the doors of r32 gtst?
why bother going 6x9s when you already have a sub? not a whole lot of point to it when you should be high passing them anyway.just go the equalivant 6''.will be easier for you guys to fit and with a sub you more then likly wont be able to hear a difference and will probly be cheaper then the 6x9s.
6's into the doors isnt a problem.does it still have the 5x7s in it at the moment? if it does just make up an MDF adapter plate and away you go.
haha its a shame DD Phil isnt on these fourms...as far as i know anyway lol.
big stereo systems in skylines/silvias are wank imo
just added wight you dont need.
spend the money on mods to get the unleashed power out,
or just call me a dickhead and tell me to shut up, lol
your a dickhead, shut up :thumbsup: lol, my car seems to handle the weight just fine :ermm:
