Hi all,
Has anybody used Import 101 in WA as importer? Are they trustworthy :cool:?
Thanks. :P
Yeah, I imported my GTR 2 years ago with them, very good.
I know a few other members over here that have been happy with the service.
Hi all,
Has anybody used Import 101 in WA as importer? Are they trustworthy :ermm:?
Thanks. :banana:
i imported my 32 gtr nearly 3 years ago through Danny (IMPORTS101) excellent service never had a problem
i would reccomend them to anyone to import a car from Japan
I live in vic but know about import 101 just from browsing internet. their website seems to be quite informative, especially in breaking down import cost. that's y i want to find out more about them from anyone who has experience dealing with them. Seems like they are a good choice :P
Hey!!!... yeah my partner and i just imported our R33 GTR Vspec through Imports 101 (Danny) they were very helpful through every step, good pricing, and would recommend to anyone in WA who is looking to import from Japan!
Awesome bunch of guys!
  • 1 year later...
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
