Hi,
Im just in the progress of putting on my JJR Split Dump/Front Pipe when i ran into a problem. There seems to be a bar that is running from the turbo to the motor. It is in the way of the top pipe. Can the bar be bent out the way? I can put the dump/front on by bending the bar away a little bit but its leaning on the top pipe, would this be a problem?
Thanks :cool:
https://www.sau.com.au/forums/topic/230616-split-dumpfront-pipe-issues/
there has been a thread on this in the last i dunno 6 months.
to fit i bent mine a bit up and towards the engine from memory. but mine ended up getting wedged between the upper wastegate dump line and the exaust manifold cover. so i'd say mines been running pretty hot whenever i drive. saying this i've had no problem with it so far. If i can get around to it it would be preferrable to bend it so its touching nothing really.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
