The other day my car started to splutter while driving and i couldnt get power out of it to drive it up my street.
So today i swapped over the fuel pump to a new walbro pump to see if thats was the problem but it hasnt fixed it.
The car at idle is not stable at all it hunts and stalls if it isnt revved at all, it is also blowing some smoke aswell.
I had the turbos replaced a couple of months ago and i havent had any problems until now.
Does anyone have any idea what could be the problem because i really need my car running 100%.
try take if your cooler pipework, if there is oil one of them then one of your turbos is possibly stuffed. if not you need to do a compression test to see if it is your engine. i think each pot should be around 150 psi but not sure, anyone verify that?
Edited by Pal
ide also suggest looking at the afm. also wouldnt hurt to take a look at ur coilpacks/plugs. a failing coil, would make the car idle poorly (sound like a wrx, as its runing on 5 cylinders) and would make it run like a dog with 3 legs.
+1 for the coilpacks!
My car was/is doing almost exactly the same thing. Blowing out a bit of black smoke and smelling like fuel when you start it up? My car is at the mechanics now and waiting for a new set of coilpacks to come in. It was fouling the plugs and make the car sound and go like a tractor. Only like 30kmh, misfiring badly, lucky it happened on my street coming home.
+another1
My car is doing the exact thing :D
Got another set in the mail.
Just pulled my coil packs off and they look fine. Im glad considering they are splitfires and have only done approx 5000km, i will be pulling out the spark plugs and cleaning the afm's tomorrow night, and also trying to follow the intercooler piping to see if theres a leak. I think ill need to pull off the front bar to see all the piping though.
I just cleaned all my spark plugs thoughly and checked over the coil packs and the harness, the problem is still there. I also had a quick look over the cooler piping and couldnt see any pipes off but i need to take of the plastic guarding to see all of it properly, thats for tomorrow night. Im so worried its something engine related (because of the oil smoke) and will be major work to fix, i just spend a shit load on replacing stuffed turbos with my car off the road for 6 months so i can not afford to do any engine work.
Well they are only as old as the coils (about 5000km if that) and are $20 a pop so id rather clean them rather than replace them.
Have you got an After market ECU.
Sound like the fuel is not burning properly...or you used poor fuel from a garage.
My sister in law filled up twice at the same servo and both times she could not get the car started the next morning.
It will blow heaps of smoke and splutter and kick like a mule till it has cleared the lines.I know cause I started it by pumping the gas to get the engine to kick.
I would suggest you report it to your last fuel station. Get a new fuel filter and maybe if your like me, dump your fuel.
I suggest all you out there to either use Shell or Mobil for your fuel.
All the rest may have quality problems and may or may not address then.
Good luck with the fix
Interesting. But i first notice the problem just before i got to a servo to fill up from empty and it has gotten worse with the new fuel. Both fill ups were from Mobil.
I am running the stock computer
Edited by Cooper
    • Thanks! Will get it looked at before winter 🥶 other than that she's a mint ride love it aye
    • FWIW a lot of the local owners that do a big build tend to have cars that are perpetually broken.
    • I just got this system but haven’t installed yet I got a Moroso sealed box (defect reasons) which will be set up same as their pic The quality is high grade, the correspondence I had with the owner (former head designer for Rockford Fosgate) was unbelievable, guiding me with what I needed. Even told me not to buy some things as it could be sorted in a different way at his loss. Just a bit of a bite with the exchange rate and don’t purchase gear in 1 hit that goes over $1,000 au, lol I forgot!
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I eliminate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for? (Apple car play? Android air play)? so If I swapped head units to save using a band expander, I’d likely lose those better features to have an oem Unit operational. Better to use a band expander and retain AirPlay options and newer version of head unit     provably best to band expand it, and focus on the nav unit. th isn’t  a big deal/ would be cool to have it working  from what I can tel we use a PAL Signal and Japan uses a NTSC signal  I don’t know if there’s a co better or if the screen only reads NTSC, or if it’s the tv module that needs replacing… no big deal don’t need it but more of a curiosity thing on that!   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
