Precious Steel Pearl. I think they have a little too much blue in them but hope once they're fitted up they'll look great. I've had them machined and powdercoated and they are now MINT. 255/40/17 R specs go on them next.
They're for my R32 GTR.
Thoughts?
https://www.sau.com.au/forums/topic/230636-r33-gtr-rims/
yep. I'm a fan. 33 GTR wheels are great. if only they were +20 offset instead of +30 I would have kept mine for ever. I liked them on my 32.
The colour you chose looks really nice. should go very well on your silver car. :D
https://www.sau.com.au/forums/topic/230636-r33-gtr-rims/#findComment-4055455
Damn they look nice!!
Good choice on the colour.
Post up some pics when you put them on your car.
Will do. I've got to get some rubber sorted now. Probably from America so it'll be a week or 2.....but will def post up picks once done.
https://www.sau.com.au/forums/topic/230636-r33-gtr-rims/#findComment-4056182
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
    • Your off site links didn't work for me, and in any case it is easier for forum members if you post the pic directly either as an attachment or a link so the information is all in one place. That aside, the sills are the correct place to lift the car, whether with the factory jack or a hoist. Yes you should use rubber blocks with a slit for the seam on a hoist to avoid bending the pinch weld (where yours is currently bent, just bend it back if possible eg vicegrips), and be aware of the height you need in the blocks to clear any sill extensions to the hoist arms as it lifts If what you are doing needs access to the sills, the rear subframe bush would also be strong and secure. I'm not sure what you mean by sidemember (maybe same part I mean by sills) but be careful that your front support point is not too far back as the car is very front heavy and could overbalance.
    • Here's my first iteration - white duct tape so color is off, but this is just a straight line across the bonnet lip. From a geometry standpoint, this is probably closest to what a GTR has. Next up is some $5 white pearl vinyl and some rubber door sill trim, applied to the BACK of the bonnet lip. It's more accurate placement to the GTR, but also follows the body lines on this setup a bit more. Couple more pics on this config incoming: Again, a $5 vinyl and rubber job, it's  POC still and not how I'm gonna run this part. But one thing I'll note is that the black trim does need to "straighten out" a bit, and instead of going completely along the line of the bonnet lip, might be better suited to wrap over the "horns" of the bonnet lip, giving it a less aggressive curve up at the ends.  The correct way to do this would be to paint it body-matched and then decide how you want to make the black line. If you used paint or a pinstripe, you could have the black line go straight to the corner of the headlight where the rubber strip typically meets the headlight on a GTR.   Hope this helps!
