Item: Garrett 3076r 500hp turbo
Age: Done close to 5000km
Condition: Excellent. No shaft play
Price: $1200 firm
To Fit: T3 Flange .63 rear
Contact: Fred 0410231029
Comments: Selling this due to wanting to bigger turbo.
Oil and water lines not included. Turbo has.6 comp housing 57mm trim, good to make 400+whp wit supporting mods. Will post at buyers expense, but pick up with cash is preferred :(
http://www.pagparts.com/perfpts1.asp?pprd=...amp;cat=gtturbo
There only $1249 new with warranty... Are you flexible on the price?
Are you living in New York?
No.... well convert that to AUS $, probably about $1300, then include P&H, insurance, GST, etc. and you'll be paying at least $1600.
When doing a comparison make sure you use an example from the same country. :ermm:
HAHA point taken as i crawl back under rock... My apologies, it is late. well thats a great price! Everyone carry on as they were :banana:
hey dude what engine did u have this on
and when did it come on boost and when did it hit full boost
and what other mods do u have has well
cheers blocka
cheers blocka
I had this on a 1.8L BPT KH Laser making 330hp at the front paws on 25psi.
Boost starts to come on at 2800rpm and full boost (25psi) at 4500rpm. With this turbo, it continued to make power up to 8300rpm b4 it ran outa puff.
Click here to C my list of mods
Please no more offers of "insert a lesser turbo here" + cash my way. Can u not read in the above info stating that im wanting to go to a GT35r .63 housing so that is the only swap ill consider, otherwise cash money rules here!
Edited by Warbzy
    • Ha! well, there's your problem!  Guess the last person in there didn't have great attention to detail....
    • It seems like you guys want to behave like rabid dogs, rather than gentlemen... Knowing one has jumped in on a fellow comrades near done deal, and sniped it at the last second, how can one sleep at night?
    • My wifes says we have a spare set.
    • Good news!!! Changed the O ring today and I’ve got the “pssshhhh” back when I open the fuel cap 😂🙌🏼🙌🏼 It was 100% the O ring because that bloody thing was inside the fuel tank 😂😂😂😂😂 Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But she’s running!!! ❤️
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
