Originally posted by Silvia1992
haggle down $3000,
people get so offended when you offer them $16000 for a car they are asking $19500 for. I know ive had 10 cars and im only 22, so i bought a few.......never crashed one though.........
paul
I reckon most people here would wish you the best of luck in finding a cheap R33 'gem'. We all like a success story around here, if the comments seem a little negative then it's only because we don't want you getting stung.
good luck mate.
  • Replies 45
Personally I reckon you'd be doing well to find a manual 95 or newer under $18,500 that was worth paying money for.
even if you import them through a broker you wont do much better than that. just remember - there's about a three thousand dollar premium on the manual box.
so for a 93 - you might find one for $17 ?
btw - I had a listen to Rev210s car the other night, and it sounded pretty healthy. that flywheel makes it so much more free-revving!
yeh dude 17grand is cheap for a good skyline maybe u should save a little more and then get a nice one, u'll be really pushing it to find one for that money. and of course u'd be offended if your selling your car for 19 and someone tries to get it for 16 - wheres the logic?
Your Silvia was a complete loss because it's auto, N/A, what did u expect? ..if you're after a decent 33 with a straight body, no panel damage, immaculate interior and a well kept engine, you won't be paying budget prices. There is a shortage of good ones around. $25k+
Personally I doubt most private sales will get anywhere near their original asking prices. People are shying away from the import market due to insurance and finance hassles, this is bad for sellers.
People want imports, but sometimes, the hassles involved do not justify paying big $$$ for.
Silvia1992, keep looking dude, when you have one you like, take it to a workshop that works on these cars day-in-day-out and get them to test it. RAC are useless. Best of luck!
i baught mine recently for 19500 haggled down from 22 as payed in cash and offered various sexual favors 1995 Type m skyline White stock as a rock , but spotless in and out , engine runs well no problems! . i was once looking at ones in M Motors justl ike you for like 16000 17K! i was like yeah cheap skyline
but i had a look at a few and realllll most of them arent a particular high grade just be careful and dont buy around cannigton area :) other than that your right
and theres a guy up north in wangara that i would steer clear of aswell just ask around . dealer warrantys are worth stuff all aswell
I'm about to buy a 1994 R33 GTS25 (Non-Turbo) for $13,000. Its very stock, no mods wats so ever, just a JVC stacker. And done about 90,000km with new tyres with the stock rims. Its got all the usual features, air con, HICAS etc, but no ABS. How is this for value? Wat do u guyz think, any advise would b appreciated.
Thanx...:P
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
