Hey guys ive been having this problem latley on my 32t. I think its a fuelpump issue but not really sure. could you throw a few ideas this way as to what it could be...
When i get a little heavy footed on the excellerator the car kinda has a little touble. it doesnt produce a smooth increase in power. kinda jidders n doesnt really want to move especially at higher revs. it feels as though not enough fuel is getting through or maybe no sparke or something. My injectors where cleand n flushed about 10,000kms ago and the spark plug were changed at that time to ..
car is totally stock at the moment...
i do have a bosch 023 fuel pump just havnt installed it yet... is installing one of these pumps something that i could do or does it require some sort of modification??
thanks for you help!
https://www.sau.com.au/forums/topic/230692-is-this-a-fuel-pump-problem/
ye that happened to both my mates in their r32's........ the way i can explain the sound is when u put foot down it cuts out and sounds like the car has Bee-R turned on haha its fuel pump...... my mate got a new pump and instantly fixed problem........
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
    • Some sense has prevailed! What kind of idiot spends money on intake, heads, and cams for a N/A motor in 2025? Lol. What maroons. Source:I am King Maroon.
    • So, cams are not getting installed......yet  Had a good chat with MX5 Mania about intakes, they recommend not to get ITB's, they recommend a plenum style for the NC So, one of these puppies is being ordered, with a larger TB to suit, when it arrives from the US the car will go in for the cams and intake I'm also getting a fancy rear box bit for the air filter box which will suit the new TB size
    • Clamp meter is pointless. Unless you're trying to keep average current under a set value for some weird reason (maybe you undersized your wiring?), then you'll get no useful info. What you're really trying to target is the flow of fuel coming back to the tank. You want some, but not a lot. You also want to make sure fuel pressure remains stable.   So, fuel pressure gauge, and fuel flow gauge. Set it up from that.
