Hey guys ive been having this problem latley on my 32t. I think its a fuelpump issue but not really sure. could you throw a few ideas this way as to what it could be...
When i get a little heavy footed on the excellerator the car kinda has a little touble. it doesnt produce a smooth increase in power. kinda jidders n doesnt really want to move especially at higher revs. it feels as though not enough fuel is getting through or maybe no sparke or something. My injectors where cleand n flushed about 10,000kms ago and the spark plug were changed at that time to ..
car is totally stock at the moment...
i do have a bosch 023 fuel pump just havnt installed it yet... is installing one of these pumps something that i could do or does it require some sort of modification??
thanks for you help!
https://www.sau.com.au/forums/topic/230692-is-this-a-fuel-pump-problem/
ye that happened to both my mates in their r32's........ the way i can explain the sound is when u put foot down it cuts out and sounds like the car has Bee-R turned on haha its fuel pump...... my mate got a new pump and instantly fixed problem........
    • Hey guys, Just thought it might be of interest to owners of the RB25 det NEO motor, that awesomeness Nitto are in the late process to produce an engine gasket kit by end of Jan 25.  I think obviously there will be an 25det kit too. cheers, Ian
    • He is around but doesn’t really do automotive stuff anymore, mainly does commercial work now
    • Shortly after I do the usual full exhaust/ fmic/fuel pump/ R33 turbo and still get flogged at the lights by i30Ns
    • Is Chris from Craved Coatings still around? He is an ex SAU guy and did great powder coating (back in the day at least)
    • Bumping this thread yet again, has anyone ever tried putting yet another vacuum regulating valve on the hose that goes between the turbo inlet? Something local owners have mentioned is the Radium breather pipes de-restrict the valve cover but it actually produces an undesirable outcome in practice, way too much air is sucked out of the crankcase and a ton of oil comes with it as well. As far as I can tell the PCV diaphragm in these modern euro wet sump performance engines is active during boost as well, there's just a check valve to block boost from entering the valve cover and crankcase as there's no inherent check valve function in these diaphragm-type valves. Hopefully I'll be able to try some of this out soon. The Volvo XC90 4.4 V8 has a nice external version of these things.
