hey all just got my car tuned with the new gear and the place i got it done at said it got 265 but thats all they said which sucks cause i wanna know if it is kw or hp we are talking about,
these are the mods
kamakato exhaust
550cc injectors
hybrid fmic
apexi pod
ebc set at 13 psi
emanage blue ecu
hypergear tr43 gen 2 turbo
bosh 040 fuel pump
z32
all in a r33 with a stage 2 shift kit
any help muchly apresiated
(excuse my rank spelling)
https://www.sau.com.au/forums/topic/230701-would-thid-be-in-kw-or-hp/
Since you, presumably, paid for the work you should have recieved a dyno log when done. Otherwise just pick up the phone, ring your tuner and ask him, no point any randoms trying to guess what you made other than for self gratification..
true but its a sunday and im itching to know haha
hmmm... that is a hard one, cuz I have a tr43 aswell...
my mods are similar to yours, but with a pfc...
my injectors and z32 are going in the car as we speak :laugh: so it has been estimated with those bits and pieces going in and about 15psi
that the car would be roughly around the 250kw mark...give or take..
at the moment, the afm and injectors are at 110% and 100% and the max I power I got with them was about 204kw..at 11-12psi.....
so if its had a good tune,etc. etc.. it could be at 265kw... considering a tr43 will handle roughly 400hp..
Regards,
Adam
it sound like in HP. can you put up the dyno sheet? TR43 standard make 230rwkws (331HP) at 14psi with stock injectors and AFM after a good tune. You should get 215rwkws just by using 98 fuel and slight timing advance. Check to make sure your cat is not restricting flow, and Please Make sure the internal wastegate is shut probably. Lot of people doesn't adjust the wastegate rod after rotating the housing on it.
below is off a rb25det all stock fuel and afm running a dr.drift remaped ecu.
Edited by hypergear
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
